[DFW] What have you done to your G Today?
Old Dec 18, 2011 | 08:01 PM
  #11056
r1forever80's Avatar
You need to be more specific james on saying the rear. Any rear camber kit get do that if they have enough thread and that would only be +5 or -5 degrees of camber which you really cant use all of that unless you have toe arms i believe. the spl front v3 is only like +1.5 degrees
Old Dec 18, 2011 | 08:03 PM
  #11057
JaE35's Avatar
Moderator
G35 Sedan
I'm going off of what is marketed not your fancy pants observations lol
Old Dec 18, 2011 | 08:04 PM
  #11058
keep reaching James. lol
Old Dec 18, 2011 | 08:12 PM
  #11059
Deemo's Avatar
They don't offer more adjustment than ichibas?
Old Dec 18, 2011 | 08:14 PM
  #11060
Deemo's Avatar
I still have -2.5 camber in the rear and my arm is maxed out..
Old Dec 18, 2011 | 08:16 PM
  #11061
JaE35's Avatar
Moderator
G35 Sedan
Must not have the toe bolts?
Old Dec 18, 2011 | 08:36 PM
  #11062
Deemo's Avatar
Pretty much I got the toe bolts.
Old Dec 18, 2011 | 08:40 PM
  #11063
well then your toe bolts are maxed out which means you cant get anymore positive camber without messing the toe up. i doubt the arms are maxed out before the toebolts get maxed out
Old Dec 18, 2011 | 08:46 PM
  #11064
JaE35's Avatar
Moderator
G35 Sedan
Would it be a bad thing to extend the toe bolt hole in that situation?
Old Dec 18, 2011 | 08:49 PM
  #11065
Deemo's Avatar
^+1.. I've heard of people doing that
Old Dec 18, 2011 | 08:50 PM
  #11066
the problem is that the toebolt hole can only be elongated so much if you use the toebolts because of the slots that the bolts are in. You could replace it with a regular bolt that doesnt have the flange on it but setting the adjustment would be a pain. Best thing to do imo if you wanna stay low will little neg camber possible is to get true coils in the rear with toearms and lockout bolts.
Old Dec 18, 2011 | 08:53 PM
  #11067
JaE35's Avatar
Moderator
G35 Sedan
That makes sense
Old Dec 18, 2011 | 08:58 PM
  #11068
sexyrob's Avatar
http://www.splparts.com/chassis-V35.html
Rear Adjustment spec: Camber adjustment range is +/- 10deg from stock arm.
Front Camber adjustment range is -2.5deg to +1deg relative to stock arm;
Old Dec 18, 2011 | 11:42 PM
  #11069
bound4VIP's Avatar
I did his alignment on Saturday, the camber wouldnt go any less than -2.5°. I tried everything. Those camber arms would not go any further.
Old Dec 18, 2011 | 11:48 PM
  #11070
On the rear? Its like a big turnbuckle so it would come apart if the arms got maxed out i thought?
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
