Transmision Chatter.. oldy but goodie right?
Old Mar 14, 2010 | 08:26 PM
mach2's Avatar
At the risk of being flamed, I did do some looking on Z forums through yahoo and in our forums as well so just for my own confirmation..
Manual transmission chatter is normal for our cars right?
I get it on a steep hill in nuetral, in nuetral after a hard drive and some times after releasing a gear and always as I turn the car off.
Im sure this has been addressed so I am exposing my noobness here but Im just wanting to see if that is the consensus.
The delaership says my clutch may be out in 6-8 months becusae of how hard it is to push in, but the car is an 04 and only has 41K on it??
Any thoughts?
Old Mar 14, 2010 | 08:41 PM
GWord256's Avatar
Probably means the springs are going bad. I won't say your approaching catasthrophic failure (highly doubt it).
Try this. Turn off the car with the clutch in. Then turn off the car with the clutch out & in neutral. I'll find my transmission book in the mean time.
Old Mar 14, 2010 | 08:54 PM
mconklin's Avatar
I replaced my clutch at 38k, my transmission was always a little noisy but seemed to get a little worse when my clutch went out.
Old Mar 14, 2010 | 08:57 PM
mach2's Avatar
trying it now brb
GWord256's Avatar
To quote Robert Bowne:
A sound like a gear rattle in some cars is actually from the flywheel. ... Dual mass flywheels are made in two parts. The outer ring of the flywheel is a heavy weight that is seperate from the flywheel's hub ... Between the hub and the outer weight are springs or rubber blocks that dampen drivetrain torsional vibrations. This is similar in function tot he sprung hub of some clutch discs.
This setup works well until the parts start to wear. The constant movement between the inner and outer parts of the flywheel wears away metal until play developes in the pivots. Play in the pivots allows the outer ring to rattle back anf forth, creating noise at idle. ... This problem is common on newer BMWs, as well as Corvetts, the manual transmission Cadillac CTS, some Nissans, ...
Old Mar 14, 2010 | 09:05 PM
mach2's Avatar
Holy **** clutch in it pretty much disapears! Especially when I cut it off.
Old Mar 14, 2010 | 09:06 PM
mach2's Avatar
Man thats gotta be it, so my fly wheel i going bad i bet FUUUUUUUUUUU
Old Mar 14, 2010 | 09:14 PM
GWord256's Avatar
That, and I'd get a second NON-DEALER opinion. You may want to search this thread for a transmission place. I don't know if anyone has posted a transmission shop but surely someone knows a good place.
Any tech (not the cashier) should be able to come up with a few theory's in just a couple seconds.
Old Mar 14, 2010 | 09:21 PM
GWord256's Avatar
Another snipit from Robert Bowne:
Another frequest sign of a bad motor mount is clutch chatter. ... clutch chatter is almost never caused by the clutch disc or flywheel. Usually, it is the result og overly flexable motor mounts ... As the drivetrain takes some of the engine's torque, the pressure on the mounts eases and they spring back. This oscillation continues and the engine and transmission rock back ad forth. As soom as the clutch stops slipping, the mounts return to their neutral position and the oscillation goes away.
It's all very confusing... I just wich I had all my books in .pdf form for simple searching.
Old Mar 14, 2010 | 09:25 PM
mconklin's Avatar
yup..and just so you know the stock flywheel is a grand!!! I went after market when they told me that. I have a lot of chatter with the after market but I can also dump the clutch at 3500-4000 rpms without it sticking to the floor.
check out the vendor area and you can get a clutch flywheel package for 750-1000, you will be looking around 400 for labor to have the work done, I recomend getting a s.s clutch line and s.s pivot bolt while your at it.
Old Mar 15, 2010 | 02:27 AM
twalls's Avatar
CLUB MODERATOR
Ah.. the reason I got an AT...
Told you these guys knew what they were talkin about Mach..
Old Mar 15, 2010 | 09:20 AM
mach2's Avatar
That is odd, is sounds like the first quote hes saying that a bad fly wheel can cause the issue and the second thta its rarely the fly wheel?
Old Mar 15, 2010 | 09:49 AM
kvangil's Avatar
Don't let it scare you. Just because it "wears" to the point of chatter does not mean it's about to give out. BTW, my clutch is also harder to depress than my previous cars. Mine's been making that chatter for the past 3 years. Clutch still grabs strong, and I'm at 81K miles now. At 50K miles, the dealer said I should replace my "worn" clutch. I think I have at least another 10K miles left in it....
Old Mar 15, 2010 | 01:01 PM
mach2's Avatar
Yea it is worrying a bit, im going to start pricing clutch kits, and findinig the most streetable one. So once the time comes all i have to do is pay for labor. I will obviously need a flywheel as well from what ive been reading. Do clucth kits typically coem with everything?
Old Mar 15, 2010 | 01:10 PM
mach2's Avatar
whats a clutch line and pivot bolt for? and I missed the second half of your post thanks for the work estimate numbers, are those from a shop you use?
