[DFW] Local craigslist deals
Old Aug 7, 2011 | 11:29 AM
  #646
SpEcToR's Avatar
OEM 19s (i may be flexible on price)
http://houston.craigslist.org/pts/2509551762.html
Old Aug 7, 2011 | 12:02 PM
  #647
Trickstyle's Avatar
Originally Posted by LordFappington
High egt will melt your turbine and cause **** to fly all up in your intake and eventually into your motor possibly blowing up your ringland and anything else not able to handle the higher than normal temps.
what turbine? the one on your turbo? if so how does that effect the exhaust gas temp? if the turbos spinning faster wont it push more air in? i thought a "rich" mixture had more fuel than air in the ratio... or am i A$$ backwards here?
sooo rich mix exhaust burns hotter?
Old Aug 7, 2011 | 12:13 PM
  #648
LordFappington's Avatar
Hes not running rich the numbers he posted dont add up. 550cc injectors running rich on 10psi with 500hp. If he were to be in the 500's he would definately but running very lean.
High EGT will blow these rings up
Old Aug 7, 2011 | 12:54 PM
  #649
This formula is used
Airflow formula
AFR is somewhere below 13 if hes running rich.
Airflow of a t60-1 .58A/R is rated at 47lbs.. so WA is 47lbs
Lets determine what the 500hp flywheel goal in relation to whats needed for WA
500x12AFRxBFSC of .55/60 = 55lbs/min
You need a turbo that efficiently moves that amount.
the t60 in the turbonetics efficiency is at 47lbs/min. This turbo is way too small for even that amount of flywheel hp. Its not saying it cant be done, but your trying to ram all this air into the a turbine causing lots of backpressure.
Old Aug 7, 2011 | 01:11 PM
  #650
BlueBOB's Avatar
Lol... look at the lord busting out the formulas
Old Aug 7, 2011 | 01:15 PM
  #651
You use this formula to account for displacement
MAPreq = Manifold Absolute Pressure (psia) required to meet the horsepower target
· Wa = Airflowactual(lb/min)
· R = Gas Constant = 639.6
· Tm = Intake Manifold Temperature (degrees F)
· VE = Volumetric Efficiency
· N = Engine speed (RPM)
· Vd = engine displacement (Cubic Inches, convert from liters to CI by multiplying by 61.02, ex. 2.0 liters * 61.02 = 122 CI)
(55x639.6x(460+130)) / .92x(6500/2)x213.57
(20755020 / 638574.3) - sea level 14.7 equates to needing almost 18psi
Old Aug 7, 2011 | 01:16 PM
  #652
JaE35's Avatar
Moderator
G35 Sedan
Old Aug 7, 2011 | 01:20 PM
  #653
yeah the chinese in me came out with a fury.
Old Aug 7, 2011 | 08:15 PM
  #654
number1punjabi's Avatar
Just replaced my front wheel hubs, found out one of the hubs was still in good condition so if anyone needs one hit me up with a offer!!
-and thanks Jake for replacing em!!
Old Aug 7, 2011 | 10:33 PM
  #655
g35man04's Avatar
CLUB MODERATOR
which hub did you replace?? I may need one...I need a passenger front.
Old Aug 8, 2011 | 12:52 PM
  #656
I replaced both of the fronts....the one I have for sale came from the driver side, but it should fit either side.
Old Aug 9, 2011 | 02:06 AM
  #657
faiz23's Avatar
What was this guy smoking when he typed up this ad. G37 coupe for $8k
http://dallas.craigslist.org/mdf/cto/2536947866.html
Old Aug 9, 2011 | 02:08 AM
  #658
faiz23's Avatar
Skyline for sale
http://dallas.craigslist.org/dal/cto/2519011141.html
Old Aug 9, 2011 | 02:11 AM
  #659
gshadyz's Avatar
WoW O_o" thats the R36 model
Old Aug 9, 2011 | 07:43 AM
  #660
sexyrob's Avatar
oh wow, even comes with a little yellow tree air freshener
