>>G35 tires issues..any one??
Old May 22, 2010 | 02:20 AM
SiouxFallsG35's Avatar
Mind sharing your slow-wear alignment settings?
Old May 22, 2010 | 02:26 AM
T3K_V35's Avatar
03' track... Soon to be race car.
not that hard to do.....set the front and rear toe as close to zero as possible. Attempt to get the camber under -1.5 degrees. In some cases this just wont be possible due to spring droop. That should slow down the tire wear. Front toe is really key, the closer you can get it to zero the better.
Old May 23, 2010 | 01:18 PM
ishraq2910's Avatar
will a Front & Rear Camber Kit will fix this problem?
Old May 23, 2010 | 01:27 PM
Kirks06's Avatar
The problem is our cars do not have camber adjustments from the factory. The adjustable upper a arms will solve this problem I got the ichuba's for about 250 shipped for the set and they seem to be a high quality pieces. So if you are wearing your tires investing in the adjustable a arms makes sense, especially if you are lowered.
Old May 24, 2010 | 05:01 PM
T3K_V35's Avatar
Yes a camber kit will help. Once again though, the priority is setting the toe correctly. Castor doesnt wear tires, and camber wears at a very minimal rate. When you alter the alignment more toward a non-tire wearing setup, dont expect the car to handle quite as well. If you want to know more about alignments and handling i sugest reading "High-Performance Handling Handbook" by motorbooks workshop. Its a great source of information....even if you do know about cars.
Old May 25, 2010 | 11:10 PM
Just had a reputable performance shop get front and rear toe very close to zero. No noticeable negative effects yet although I'm driving pretty modest right now. Thanks for your advice.
Old May 26, 2010 | 09:14 AM
T3K_V35's Avatar
no problem...thats why im on here
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
itschuckster
Jul 25, 2015 08:07 AM
laksjd84
Jul 24, 2015 05:12 PM
