Polishing the supercharger
Old Apr 1, 2006 | 07:34 PM
firefox's Avatar
I got all my Vortech parts in. Everything looks good, but I really don't like the satin finish. So I decided to start polishing the parts. After a couple hours of polishing, I finally got the charger polished up. Now I need to do the intercooler and pipes.
Old Apr 1, 2006 | 08:46 PM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
You so need to run down that procedure cuz I am so polishing my intake plenum currently and it is going slowly and painfully. Any useful advice would be great.
Old Apr 1, 2006 | 09:41 PM
firefox's Avatar
First, go buy one of these.
http://www.blackanddecker.com/Produc...roductID=10942
The plenum is really rough, so you will probably need to begin with 120 grit and work you way up to 400 grit. Be careful with the 120 grit it cuts through metal fairly quickly and you don't want to have any low spots.
Then stop buy an auto parts store or Walmart auto section and buy some automotive wet sandpaper 800, 1000, 1500, 2000 grit. Wet sand starting with 800 and then ending with 1000 or 1500. You can use 2000 grit if you feel that there are some really fine scratches that you want to get out, but the next step should get those out easily.
Go buy one of these:
http://www.blackanddecker.com/Produc...ProductID=6173
or any other high speed polisher/buffer with a bonnet. A porter cable polisher is even better.
The last step is to use some metal polishing compound and polish with the high speed polisher to bring out the shine. Having the right tools helps a lot.
Old Apr 1, 2006 | 11:21 PM
BeerViper's Avatar
Wow, the blower turned out awesome! Huge difference from the satin finish!! It's all starting to come together!
Old Apr 2, 2006 | 01:01 AM
So that seems like an expensive ordeal........how about I find a Saturday when you aren't busy and I can come to you for this little sharade. APPARENTLY some people (eh hum) have all of these wonderful little gadgets.....
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
