Drag NHRA, IDRC, IHRA, NDRA
Best Way to Drag G35c 6mt specifically?
Old Jul 20, 2006 | 04:06 PM
netcbc's Avatar
I notice the newbie articles but what is the best way to drag the g35c 6mt specifically? I'm new so i've heard of "dropping the clutch" is it basically revving up to 3000-4000 rpm and just letting go of the clutch? how bad is that for your car/tranny?
Old Jul 20, 2006 | 04:16 PM
norcal_chan96's Avatar
It's not the best thing for the tranny/clutch... I've ran my G over 20 times at the track from last summer and it's still engaging... But i think u should take the launch down to about 3K... Dont go higher because u just slip tire and get too much wheel hop...Plus our clutches aren't too strong and I've run into spinning my clutch... I launch mine right around 3K and my best time is 13.9 at 104...
Old Jul 20, 2006 | 04:17 PM
netcbc's Avatar
thats a pretty good time.... what rpm is best to shift at , redline every gear or ?
Old Jul 20, 2006 | 04:31 PM
Only redline first gear to set up for 2nd, but after that i shift at 6800... Our HP starts dropping after that... What times are u getting? I got injen intake, and MREV... MAke sure if ur using an aftermarket intake to clean the filter before u go out... Really helps out...
Old Jul 20, 2006 | 04:53 PM
netcbc's Avatar
haven't tried the track quite yet, just got the car 3-4 days ago, getting the hang of everything and just getting prepared for the track
not sure if i'm going to mod anything to be honest, i had a civic and had the injen, kit , exhaust and everything and it was such a pain to maintain everything...... maybe i'll just get the z tube? not sure if it's worth it though
so the best way to lunch is sit at 3000rpm and then just release the clutch?
Old Jul 20, 2006 | 07:19 PM
I am around 3K... 2800-3 is where i try to keep the revs at... Maintance wise everything is pretty easy...The g isn't fast enough stock...
Old Jul 20, 2006 | 11:13 PM
trey.hutcheson's Avatar
104mph is quite a nice trap. Congrats.
Old Jul 21, 2006 | 06:41 AM
Klubbheads's Avatar
Do u dump the clutch or feather it till u get rid of the wheel spin?
Old Jul 21, 2006 | 07:30 PM
BobbyD's Avatar
Your technique will depend on track conditions and available traction. You will need to experiment with different rpms and how you release the clutch. If you get wheelspin drop your rpms the next time or feather the clutch and see how that goes. If the car bogs you will need to raise your launch rpms. Good luck and have fun!
2003 G35 Sedan 6MT
13.96 @ 101 (stock)
Old Jul 21, 2006 | 07:36 PM
It's kinda a dump and feather.... It's all felling for me... Hard to explain... But congrats to the sedans...13.7 & 13.9 are very quick...
Old Jul 28, 2006 | 03:37 AM
netcbc's Avatar
SWEET just lunch a manual car for the first time, first i didn't understand why the car felt so bogged, then it made sense VDC was on!! once that was off, was able to pull some nice launches.......
1st gear to redline or 6800? since it was my first time, seemed a little scary cause never reved first gear so high, sounded really high pitched
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
RWDguy4238
Sep 30, 2015 12:13 AM
