Drag NHRA, IDRC, IHRA, NDRA
First time at the track
Old Aug 13, 2008 | 01:24 AM
03silVerG35's Avatar
Went to the track for the first time, only ran 3 times.
Here is my best time
2003 G35 coupe 6MT
Injen cold air
Reaction----.2949
60ft--------2.341
1/8---------9.522
1/8---------77.00mph
1000'-------12.279
1/4---------14.594
1/4---------99.31mph
Old Aug 13, 2008 | 09:12 PM
Reidonly's Avatar
Not bad for your first time! Keep at it you can drop those times even more.
Old Aug 13, 2008 | 10:25 PM
GinFLA's Avatar
very nice, drop that 60 foot and you could see some nice times.
Old Aug 14, 2008 | 05:16 PM
Thanks guys... what rpms do you guys launch from? On my first pass i tried launching from 4000rpm and all it did was wheel hop, i couldn't get any grip and ended up running 15.0. On my fastest run i went from like 2000rpm
Old Aug 14, 2008 | 08:22 PM
GinFLA's Avatar
I have an auto so its a bit different. I usually launch around 1k-1.5k.
it all depends, just keep messing around, if you bog, go higher, if you spin, go lower.
also are you just dumping the clutch or are you slipping it?
Old Aug 16, 2008 | 01:40 AM
Reidonly's Avatar
I was letting the clutch out until JUST before it grabs, revving to about 2500-2800 rpms, then releasing the clutch and quickly rolling into the throttle. Key word rolling, not just mashing the pedal. Its a very quick movement, but I don't just punch it.
Old Aug 17, 2008 | 11:09 PM
GinFLA's Avatar
hmm. Not really sure if thats like slipping, actually Im not really sure what it is. I found a link the other day that broke down why clutch dumping sucks and tells you the proper way to launch using the clutch slip technique.
try using google to find it, lol Im currently in the search of how I can cut a 2.0 60 foot on my street tires.
Old Aug 19, 2008 | 01:33 AM
I'm going back to the track this sunday, i'll try some of your tips on launching and hopefully i can cut my 60ft down. ill post the new times up when i get back.
Team STILLEN
Aug 10, 2015 08:17 PM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
joel extreme
Jul 27, 2015 11:59 PM
joel extreme
Jul 23, 2015 04:13 AM
