Drag NHRA, IDRC, IHRA, NDRA
Went to the track with my 19's and I suck...
Old Sep 6, 2008 | 04:36 PM
RBull's Avatar
Rated M
Originally Posted by DaveB
Seeing that the GTR does 0-60 in the lower 3s, it's 60' should be in the upper 1.7, lower 1.8 range. That type of launch is pretty brutal on a street suspension and I've other videos of GTR's launching and they were far more violent (butt squatting hard, front end coming up high). The video of the GTR launching shows a decent 60', but it sure doesn't look more than a 1.9 60'.
One thing we do know about the GTR is that it's prone to heat soak and Nissan dials quite a bit of power out when it's hot. It might explain the slower 60', ET, and MPH. In the right conditions (ie this fall on a NE track), I bet we'll see a few stock GTRs posting lower 11s@125mph.
Only my opinion but it's pretty hard to estimate 60 foot times from watching something, especially when it appears we can't see the full 60'.
Under ideal conditions you're probably right on what we may see of lower times.
Old Sep 6, 2008 | 04:37 PM
FI'ed G's Avatar
Originally Posted by Skaterbasist
That's incorrect.
In the same track, with the same car, you can get a 13.8 @ 100 and run 14.2 @ ~100 in the next run. It happens to me all the time (and everyone else I drag with).
I.E, drag radials have no significant impact on trap speeds, but it will surely help out their E.T.
Power/weight is usually what affects trap speeds the most. That is assuming, the person shifts correctly if they are MT.
of course 60' and shifting affect the total number. I think Auto will be a great example since you take away the shifting error. So assuming I have an Auto and I drop my 60' from 2.2 to 2.0, so my 1/8 ET will be lower of course but my Trap will be the same? So the improvement in my ET and 60' will have no affect on my Trap?
Old Sep 6, 2008 | 04:44 PM
Skaterbasist's Avatar
Retired SuperMod
It won't have any significant improvement on your trap speed. 60' directly affect your E.T.
If you want a higher trap speed, bump the boost up
Old Sep 6, 2008 | 05:01 PM
Retired SuperMod
Here's my personal example of how trap speeds aren't signficantly affected by 60's (3 runs):
Code:
Location	Date	       Time	Temp	60'	330'	1/8 ET  MPH	1000'	1/4 ET  MPH Estimated DA
CA Speedway	6/13/08     10:46AM	83	2.543	6.622	9.887	74.36	12.638	14.942	99.22	3075ft
CA Speedway	6/13/08     12:19PM	86	2.231	6.193	9.423	74.98	12.168	14.468	98.79	3290ft
CA Speedway	6/13/08     1:58PM	92	2.206	6.118	9.321	77.07	12.031	14.335	98.33	3731ft
My trap speed was actually better with a 2.5 60ft than with a 2.2 60ft. But only because the weather was getting hotter (morning track day). If the temps would have stayed the same, my trap speed would be almost identical...with the 60ft's ranging from 2.55 to a 2.206.
My highest trap speed happen to occur during my worst E.T run of the day. (My best E.T time happened at the hottest time of the day ).
Old Sep 6, 2008 | 05:17 PM
FI'ed G's Avatar
Yes, Trap is pretty much your Net HP with all the variable included. So the statement that 1. trap get lower as you ET improve and 2. Trap get higher as your ET improve are both wrong. As long as DA stay constant then you Trap will be in same range. Now does heavier wheels affect your Trap?
Old Sep 6, 2008 | 05:24 PM
ernie18's Avatar
lol i love the comment as the gtr is coming up to the line
guy " holy "
girl "****" haha
Old Sep 6, 2008 | 05:57 PM
GreenGoblin's Avatar
The goblin resurrection
That is what I am getting from skater. I see what he is saying now that the power to weight/ mechanical aspect are what determine the trap speed (with a certain range). Then 60 ft and shifts and are what will factor into the Et
Old Sep 8, 2008 | 01:58 AM
Klubbheads's Avatar
^true
Old Sep 8, 2008 | 10:04 AM
FI'ed G's Avatar
I found this.. I broke many of the rules like lowering my Street Tires to 20psi hence gearing changed, not shifting fast enough and lastly shifting around 6000rpm on 4th gear (My dyno start to drop power at 6100rpm but I could've just stayed there a little bit longer...)
So having a great momentum from the first half because of a great launch will not help? Isn't that Trap is a combination of your HP and weight? So in a short distance race then will that make a difference?
http://forums.stangnet.com/567417-tr...ined-here.html
1) Trap Speed will tell you about your HP to weight.
2) ET will tell you more about traction and your launch.
Of course ET is important to true drag racers, because the winner is the one that gets there first. However, we're not necessarily true drag racers in our attempt to get a power estimate. Honestly, ask 10 guys at the track "What kind of trap speed are you running?" and 8 out of 10 will answer with their ET - to one or two decimal places even. When you say, "No, no, I meant trap speed", they will fumble with a broad estimate with NO decimal places and might even have to pull a time slip out of their pocket to check. Try this question when you're at the track; it's almost funny.
THE DYNAMICS OF TRAP SPEED VS. ET
After running lots of quarter miles, it becomes clear that how well you do in the first 100 feet of the track is KEY to a good time. The last half of the track is KEY to a good speed.
Let's use an example of a stick-shift mini-pickup that on a perfect run, gets a timeslip of 19.50 seconds at 70.00 mph in the quarter.
Imagine that the light turns green, the truck moves two feet and the engine dies for three seconds. After restarting the engine, the driver proceeds to then complete a perfect pass. His time slip would show 22.50 seconds at 69.97 mph. The ET was 3.00 seconds high but the speed was almost unaffected.. why?? It's because his racetrack was 1318 feet long instead of 1320, and in those last two feet this truck usually gains an additional 0.03 mph. However, the clocks recorded the long time. My point? Much of a great ET is made by a great launch.
Now take this truck again, and the driver leaves right on the green light. However, he misses the 3-4 shift when he's at 1250 feet. He coasts for the last 70 feet while trying to find fourth gear. Now instead of accelerating another few mph in this final 70 feet of the track, he decelerates over this distance. His timeslip; 19.51 at 67.83 mph. Note how the et is almost perfect (only off by 0.01 second) but the trap speed is way off (over 2 mph slow)! On a good run, traveling that last 70 feet at an average of 69 mph, would have taken .692 seconds. At a 68 mph avg., that 70 feet takes .682 seconds. That's why his ET only varied by .01 seconds, yet the trap speed was 'way off'. My point here: the end of the track is critical to trap speed; shift rpm, missing a gear... these are the big players.
Hopefully these examples are clear. Neither of these runs are 'perfect' runs, it's just that one has an error at the start, one at the finish and the results are obvious. The start of the track is a big player in the ET, but a small player in the mph. The end of the track is a big player in the mph, but a small player the ET.
So for the casual T-Bricks member who wants to get a HP value, you don't have to buy slicks, or wish you had a limited slip differential. You don't really need to heat the tires in the waterbox, or launch with huge power braking. As long as people get their shift rpm right and don't miss a gear, even a rookie will get the appropriate trap speed for their vehicle.. but honing the perfect ET. requires being rude to a clutch, buying steeper gears or slicks.... hey, we're trying to make this recreational.
OPTIMIZING SPEED
If your goal is to get a good trap speed, what are your options? More power, of course - and less weight is obvious (but it will come out in the power calculations as no increase in power). Shift rpm chosen (auto or manual) and the time it takes you to shift (with a manual) are probably the most important tools you've got. Try different shift points to maximize your trap speed. Reduce rolling resistance by pumping up all tires to their rated pressure. Some people think that running lower pressure might help the traction in the rear, though. Of course more traction will help et, but with most street tires, running street tires within 5 psi of rated pressure will provide you with maximum traction in the first place.
REACTION TIME
The ET clocks don't start until you've actually moved around 8 inches (this is called the rollout)... so don't worry about trying to leave right on the green light. You could wait 5 seconds after the light turned green, and still get a 19.50 timeslip in our truck example above. Your timeslip does show a separate calculated time, the "Reaction Time", which in this case would be 5 seconds. That is the time from the light turning green until you rolled out of the starting zone. It's not a big thing for our discussion here.
THE LAUNCH
For the most part, a decrease in ET is accompanied by an increase in trap speed, but don't go overboard on the launch in your zest to rule the world. Just try to get smartly underway without spinning the tires much at all. Traction levels usually drop a solid 0.10 g when the tires start spinning.
THE HP FORMULA
Here's the formula to use to calculate HP:
Net HP = Weight in pounds* (Speed in MPH/228.4)^3
As an example, Car & Driver tested the 744 Turbo in their June 1990 issue. The car weighed 3,081 lb. without the driver.. the 'race weight' was 3,231 lb. The car ran a 15.7 second quarter at 86 mph. Let's plug it in to the formula:
HP = 3231 * (86/228.4)^3
HP = 172 Net
Volvo rated this at 162 Net. We come out a little high. Or does Volvo underrate a little? I'll say this - I've used this formula for years and that's how the 228.4 was honed - actual experience from cars that had actual power curves - and when I use it on Volvos it tends to always come out a few percent higher than the factory rating. This could simply be that Volvo underrates just a little.
Still, for such a simple formula and such a simple test, it's surprising how accurate this can be. And the best thing is - there's no arguing the numbers on a timeslip. There are always differences between a DynoJet and an Eddy Current Dyno, or G-Tech numbers, but every setup is done by someone different and subject to error. The quarter mile is arguably the best comparison a diversely located group like Turbobricks will ever have. The only real difference to argue about is the altitude of the track! You can compare ET and mph all day and have a good discussion.
HANDY RULE OF THUMB
Once you have a baseline, you should probably use a rule of thumb that each additional 6 HP will give you another mph. That's for a 3200 lb car that runs 88 mph. If you want the real formula for different weights or speeds, here it is:
HP for another mph above "X" speed: = Wt * (((X+1)^3-X^3) / (228.4^3))
For instance a 89 mph quarter vs. an 88 mph quarter for a 3200 lb car:
HP delta = 3200 * ((89^3-88^3) / 228.4^3))
HP delta = 6.3 HP
Once you're going 110 in the quarter, it would take an additional 10 HP to go 111 mph in the 3200 lb car.
60 FOOT TIME
This is the standard measurement tool to evaluate your launch. It's the time that it took you to travel the first 60 feet of the track. Naturally, patterns emerge again after looking at lots of runs and of course these correlate best to time, not mph. Typically, most everyone's 60' time will be between 14% and 16% of their quarter mile time. If it's under 13% or over 17%, this was not your best pass.
1/8 MILE VS. 1/4 MILE
After monitoring tons of good passes, patterns emerge. Typically, the mph at the quarter is around 1.26 times of the mph at the eighth, and the time at the quarter is around 1.55 times the time at the eighth. You can use these values if you only have a 1/8 mile track and get a real good idea of the theoretical 1/4 mile.
IS MY ET TO SPEED RATIO REASONABLE?
One fact of the quarter mile is; no matter how slow or fast your car is, the mph multiplied by the ET will pretty much be the same number every time. Before the NHRA changed the way that speed is measured in 1989, the product of speed and time was around 1400. Let's calculate some easy examples of this. A 14.00 et usually resulted in a trap speed very near 100 mph. A 10.00 et meant around 140 mph. A 200 mph pass usually takes around 7.00 seconds. These are still good rules of thumb to remember, but now the product is more like 1380 for us - The example from Car and Driver above comes out at 1350. (The reason for this shift is explained below). Remember, most everyone focuses on ET so much that they'll even optimize a car for slower mph if it gets them a better ET. (Rear end gearing is one way to do this). Those guys tend to have a product closer to 1300.
RESPECT MORE SPEED - A LOT. EVEN 3 MPH.
If you look at the formula again, you'll note how trap speed shows up as the cube root of power to weight. That's critical to understanding how fast one car is over another. Let's say your car does a 90 mph quarter and the guy who raced you in the other lane ran 71 mph. After the race, he wanders over to you to say the 'race was close'. Your reply: "I could have towed you and still smote you". (This might not be the best way to make friends, but yes, it is TRUE if the cars weigh the same.)
Old Sep 8, 2008 | 07:42 PM
Blackbird V35's Avatar
dont feel bad, i have the same wheels as you and 200 hp more and the best i could muster on the works was a 12.9 @ 122
I put on some real tires and got a 11.71 @ 125 2 passes later
Old Sep 8, 2008 | 09:23 PM
FI'ed G's Avatar
Do you still have a Vortech or you switched to a TT? That is some pretty sick trap for a SC...
Edit:
Never mind.. I saw your post on my350z.. You have the APS Extreme kit now.. Using the old 1350/trap, you should be able to hit 10.8ET but that is with some sick 60'. For most people out there 1380/trap is more doable so 1380/125 = 11.04ET... You got some sick car...
Old Sep 8, 2008 | 10:47 PM
Edit:
its ridiculously hard to launch with the exedy triple carbon
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
AJC128
Nov 1, 2015 11:55 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
