gear shifter stuck
Old Aug 24, 2009 | 11:52 AM
MidnightG35X's Avatar
Originally Posted by Shincrono
This is exactly what I had to do.
Thanks dude
Glad I could help
Old Dec 30, 2009 | 02:05 PM
dennitak's Avatar
Will this problem be covered under powertrain warranty?
I have a same problem with my 05 G35 Sedan. I wonder if it will be covered by factory powertrain warranty (it's not like the problem is caused by my negligence/abuse)
Old Apr 9, 2018 | 11:53 AM
Arturo Shepherd's Avatar
my g35x wont shift into park
Ran across an old post. i just brought an infiniti g35 crashed and when I got it they had the car in neutral. When i tried to shift the car into park the car wont shift. Any ideas that could help?? Not looking to spend a lot of money.
Old Apr 9, 2018 | 03:03 PM
telcoman's Avatar
Veteran: Army
New transmission perhaps?
Telcoman
Old Apr 9, 2018 | 06:06 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The shifter itself physically won't move or it WILL move but the vehicle doesn't engage into park?
Old Jun 14, 2022 | 10:04 AM
MarlonG35's Avatar
Base
Just picked up an '08 G35 and I must have touched something while I was removing/ disconnecting the radio fascia panel for wrap because I started getting the Shift to P error and now the Shift is stuck in Park and wont move unless the press down on the white shift release. I can see from the side that this little rod that fits into a little white plastic plate of sort isn't getting pushed all the way to the top. It's being hindered. I will try this fix later and report back. Everything was fine before I started unplugging radio and lighter and taking panels off. Hopefully it's a simple fix
Old Jun 14, 2022 | 03:36 PM
jbarnett250's Avatar
MarlonG35, Sorry I can't help specifically but I'm pretty sure I recall this being discussed recently. If you do a search on the search bar with some key words from your post I bet that thread will come up. And I think your problem is different than this thread. Yours sounds like shift interlock problem while this old thread is about some kind of mechanical binding in the shifter assembly but not caused by the interlock.
Dallsinghjr1
Sep 17, 2023 11:25 AM
alessandro
Oct 8, 2015 09:29 AM
gatorglaze
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
