another clutch question
Old Jul 28, 2006 | 02:22 PM
t3h pwnz0r's Avatar
I thought there may be something wrong with my clutch because it felt softer after a bad launch, but I did the test where u put it in 5th at 40mph and floor it, and there was no slippage at all. Are there any other 6mt owners here that just have a really soft clutch that also engages really high?
Old Jul 28, 2006 | 02:45 PM
trey.hutcheson's Avatar
When you floored it, did you immediately drop the clutch, or did it rev down before you clutched-out?
I've never driven anything but on 05, but my engagemnt was always near the top of the pedal travel.
Old Jul 28, 2006 | 02:56 PM
t3h pwnz0r's Avatar
Not sure I understand what you are asking. I was cruising at 40 in 5th and just hit the gas all the way.
Old Jul 28, 2006 | 03:11 PM
Do this test. Get on the interstate and cruise at around 80(3k rpms). Clutch in, and while the clutch is depressed, floor it to redline. Then just drop the clutch. If the car jerks and the rpms immediately fall back to 3k rpms, then the clutch is fine. If it slips, then you've got problems.
Old Jul 28, 2006 | 03:14 PM
t3h pwnz0r's Avatar
Will do but that sounds like it could screw it up even more. Are u sure that's safe?
jsimonk
Dec 22, 2023 03:49 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
