3.90 gears????
Old Dec 20, 2006 | 11:45 PM
rlwjr1's Avatar
3.90 gears????
I understand that with this swap I will lose cruise control.
Along with this will the speedometer accuracy be affected also???
Old Dec 20, 2006 | 11:52 PM
rcdash's Avatar
no i believe the speed sensors are located beyond the diff at the wheels
Old Dec 20, 2006 | 11:55 PM
rlwjr1's Avatar
Do you have said gears??
My question was kind of a bait. I'm figuring that if cruise is lost that means the vehicle speed sensor will be out of whack which would also cause the speedometer to be off.
Old Dec 21, 2006 | 11:30 AM
rlwjr1's Avatar
Old Dec 22, 2006 | 10:18 AM
helldorado's Avatar
Cruise control is based off combined readings of the wheel speed sensors and transmission revolution sensor. There's an allowable variance for the engine rpm in any gear at a given speed, the shorter gearing pushes it outside of that variance so your cruise control will not work.
Console gauges such as speedo and odometer are based solely off the rear wheel speed sensors.
Old Dec 22, 2006 | 11:48 AM
rlwjr1's Avatar
Cool, thanks. Now, wouldn't it make since that this could be reprogrammed by the reflashers such as Technosquare or Altered Atmosphere???
Old Dec 22, 2006 | 01:39 PM
helldorado's Avatar
It would make sense, but good luck. I just tired to get AAM to delete the trouble code, but they couldn't do it.
Thebaws11
Jul 2, 2021 11:36 AM
Since 1983
Sep 19, 2015 10:26 AM
FRUG35
Sep 11, 2015 03:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
pasjr1972
Sep 1, 2015 10:17 PM
