NOISEY! NISMO Flywheel,Pres.Plate,Clutch.HELP!
Old Nov 22, 2003 | 11:59 AM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
Hi Guys,
Just got my 2003 (6300 miles) G35c6mt. back yesterday after a New Transmission was installed by Infiniti. The 3rd gear syn.went out.
Anyway, I had them install the New NISMO R-Spec:
FLYWHEEL #12310-RSZ30-US
PRESSURE PLATE(Cluth Cover) #30210-RSZ30-US
CLUTCH DISC # 30100-RS252-US
When they put the New Trans. in. Of course the NISMO-R
products are not warranted by Nissan at all, but thinking these are matched componants made by NISSAN for the 350Z/G35, I figured it would be Safe & Proven way to go. Boy was I WRONG!
I'm getting a Loud Buzzing sound from underneath the car from 1,500-2,500 RPMS especially when cruising at say 50 MPH in 5th gear w/ the engine lugging during acceleration.It's not the Trans., it shifts Great.
This ia a Very Loud metalic sounding Buzz. I've talked to one Performance shop that speacializes in Z & G cars and he thinks it's a Harmonic Resonance from the Solid Nismo Flywheel & Springless Nismo Clutch, as opossed to the Stock Dual mass Flywheel & Stock Spring Clutch. He has seen this happed w/ lightened Flywheels before. His theory is that the new NISMO Clutch & Flywheel aren't absorbing the engine harmonics Like the Stock setup does in that RPM range. He thinks putting a Springed Clutch Disc back in w/ the Nismo flywheel would help absorb that resonance & hopfully solve the problem.
I wander if NISMO is aware of this Problem, maybe that's why these(R-Spec) pieces aren't recommended for the street.
I've had Performance cars all my life w/many Mods, and I haven't had this come up before.
HELP, your thoughts & Input are appreciated!
Thanks,
RugRatCoupe
Old Nov 22, 2003 | 12:05 PM
RugRatCoupe
20 Year Member
Re: NOISEY! NISMO Flywheel,Pres.Plate,Clutch.HELP!
New Trans. Going In...
Old Nov 29, 2003 | 12:01 PM
dan66's Avatar
I have the same set up just installed last week. I have to agree that you might have a buzzing noise when you try to accelerate and you are in a higher gear then necessary. The fix is to be in a lower gear, and then shift up. You do not want to drive at 50 mph in the 5th gear. I usually stay in the 2nd-3rd under 60 and 3rd-4th after 60mph,depending on how hard you want to accelerate. The performance for this combo is truly outstanding compared with the stock. I think if you will change your driving style a little bit, you will be extremely happy versus paying more for a potential fix.
Old Nov 29, 2003 | 02:50 PM
narkotic's Avatar
So you install performance products, w/out the knowledge of knowing the pros and cons... you should have done your research, all over the 350 boards where they have replaced their flywheels they've gotten mass amounts of new noises..this is to be expected with a new lightened flywheel.
good luck
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Old Nov 29, 2003 | 08:34 PM
DragonGcoupe's Avatar
Why would you leave it in 2nd - 3rd up to 60? So you can keep ur revs high for no reason?
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Nov 29, 2003 | 10:37 PM
Edretti's Avatar
You are definitely hearing the "cement grinder" normal sound.
Edretti
2003 Infiniti G35 Coupe 6mt Loaded Brillant Silver
http://www.cardomain.com/id/edretti
Old Nov 29, 2003 | 11:54 PM
RugRatCoupe
20 Year Member
narkotic,
I did the research. Even P.M.ed "infidsg35" who has a JUN Lightened Flywheel. I Just thought playing it safe with NISMO stuff would be the way to go.But I still have a noisey flywheel.
Aside from some noise between 1,500 & 2,500 rpm, I really CAN tell a differance with this setup.
The NISMO clutch is awesome. It'll engage smoother than the stock Clutch & Pressure Plate was ever able to, or it can Jerk the tears right out of your eyes if you let it out too quickly. The car is so much more responsive now with the NISMO lightened flywheel. The additional quickness of the car makes it Feel like I've gained 15-20 HP.
Don't get me wrong, All in all I'm very Happy with the Performance of the New NISMO Clutch, Pressure Plate & Lightened Flywheel.
Just Dissapointed in the loss of Smoothness & the Extra Noise after going with the (Hopefully More Proven) NISMO Stuff.
Thanks for your Input guys & Take-Care
RugRatCoupe
Old Nov 30, 2003 | 01:15 AM
humanRESEARCH's Avatar
Loss of smoothness shouldn't be a surprise...You're going to lose some street manners when you start playing with the flywheel and clutch...At least you seem to have a good attitude about it
"All the Power in the World resides in the Eyes..."
Old Aug 7, 2013 | 03:19 AM
dukehotty's Avatar
You should switch back to stock/OEM.
Old Aug 7, 2013 | 03:21 AM
Xet's Avatar
Xet
trolloolol?
Old Aug 7, 2013 | 07:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
He does this from time to time. Moved to the appropriate forum and closed for future reference.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
