5th won't engage!
Old Jan 31, 2007 | 01:19 PM
klg35's Avatar
5th won't engage!
driving around one and bam.....5th gear will not engage at all......so i put in neutrual and try again.....nope.....all other gears are ok, except for the occasional 1st and 1-2 notchiness......car is at dealer.......anyone had this happen before? what happened? searched, but nothing on about 5th shows up...
Old Jan 31, 2007 | 01:59 PM
nm3th's Avatar
Did you check the guide plate? Maybe it got loose. When I installed my RE short shifter, I couldn't get into 5th until I readjust it.
Old Jan 31, 2007 | 02:04 PM
BayAreaRefuGz's Avatar
i fly low
rofl. yeah, that happened to me when ryan (jdm r tab) and i were installing my RE short shifter, it said to shift to 6th gear when placing in the guide plate. then when i shift up to 5th, it wouldnt even budge. finding out it wasnt alligned, i had to kind of shift up and slanting it slighty to the left.
if you were installing a RE short shift or Nismo, you might want to loosen the 3 bolts that holds down the guide plate. if you line up the guide plate where you can shift 5th and 6th easily all gears should follow through. it's something you could do and not pay the dealership $40+ for an adjustment. just my .02 cents
-jeff
Old Jan 31, 2007 | 02:22 PM
klg35's Avatar
will look into guideplate........since car is at dealer now, i'll see what they have to say......hopefully the 1st and 1st-2nd notchiness will have them replace the tranny....that's a big hope though.....
thanks fellas......
Old Jan 31, 2007 | 03:34 PM
Jason@Riverside's Avatar
guide plate is the first thing that came to mind for me as well...
Hogbone
Sep 28, 2015 06:44 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
mattdg35
Sep 14, 2015 11:28 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
