Auto Trans Fluid.....
Old Mar 17, 2007 | 11:50 PM
  #31
IP05G35's Avatar
If you do the drain and fill method how many quarts do you need?
Old Mar 18, 2007 | 11:27 AM
  #32
sloppymax's Avatar
if you simply drain without dropping the pan then plan on around 4.5 - 5 quarts coming out. if you drop the pan then plan on about another .5 quart or so coming out. with the pan down you can clean the metal debris from the magnets and get it out of the system along with getting a little more fluid out. the 06 fsm shows 10 7/8 quarts as the capacity. i think you would be safe with 6.
Old Mar 19, 2007 | 03:43 PM
  #33
joedaddy1's Avatar
i just did mine for the first time. 57k miles.. it was REALLY clean..
exactly 4 quarts came out.. i put in 4.1 quarts~
Old Mar 19, 2007 | 05:04 PM
  #34
sliderg35's Avatar
I did mine on the weekend. Only got 3.5 quarts out. That's all it took to fill as well. Mine wasn't so clean!
Old Mar 19, 2007 | 09:05 PM
  #35
IP05G35's Avatar
Do you fill at the dipstick tube?
Old Mar 19, 2007 | 09:34 PM
  #36
sliderg35's Avatar
Yes.
Old Mar 19, 2007 | 10:37 PM
  #37
lawrence's Avatar
Originally Posted by jjyellow
Please dont put an inline filter for your tranny. I have a tranny shop and have seen a lot of transmissions go bad because of them. A lot of people forget to change them and eventually they get clogged and cause the tranny to go bad. The mesh screen in the valve body is all you need to clean. Just take the pan off and spray it with carb cleaner. If you want to change the screen int the tranny, you are going to have to drop the valve body, b/c i belive 2 of the bolts uses nuts on top of the valve body to hold the screen in alos.
please , please , please no carb cleaner in, on or around any trans.
only use brake cleaner.
Old Apr 5, 2007 | 07:40 PM
  #38
kegels's Avatar
I'm planning to do a tranny flush very soon. I called Redline and they said the D4 ATF is also compatible with the Nissan J Matic. I'll probably end up using Redline since I can get it at my local Napa Auto parts.
Old Apr 5, 2007 | 10:40 PM
  #39
Neal376's Avatar
i think i read in the FSM a list of other fluids besides J-Matic that meets specification
also, the mechanic at my dealer told me that you can disconnect the coolant return line...feed it to a bucket if you dont have a large enough catch pan....still need two people to do it tho
Old Apr 6, 2007 | 10:34 AM
  #40
Q45tech's Avatar
The J Matic has a special additive to match the new dual clutch lock up mechanism. It might be possible to modify the stick slip characteristic of PREMIUM ATF to emulate J Matic.
The additive smooths the engagement and disengagemnt of lock up.
Lubeguard BLACK might work with experimentation?
Unfortunately errors don't usually show up until after warranty around 100k.
Old Apr 6, 2007 | 03:34 PM
  #41
kegels's Avatar
I called around to see how much the dealers charge for a tranny flush and I decided to let them do it. Cost is $190 and they use J matic. It'll cost me almost the same if I were to buy the fluids and take it to an independent shop.
By the way, i'm taking it to Frontier Infiniti.
Old Apr 6, 2007 | 04:22 PM
  #42
erdog's Avatar
Kegels, that's a very interesting username
Old Apr 6, 2007 | 06:14 PM
  #43
kegels's Avatar
Don't forget to do your Keges.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
