Question - 3.3 Open Diff to 3.7 VLSD
Old Mar 27, 2007 | 09:24 PM
OCG35's Avatar
Here's the deal... I have 04 AT base sedan = 3.3 FD w/ open differential.
I am getting 3.7 FD gears - a while back I asked if it is worth it to do gears with open diff - the consensus was no and I agree.
So... I sourced an OEM VLSD from an 06 350 Z and will be purchasing 3.7 FD new. The trick is getting it all in my existing pumpkin. The VLSD is differential only, not entire pumpkin.
I called several shops to get quotes and timeframe and as expected most said several days to a week. I figured that’s logical since this is basically rebuilding the existing - not swapping pumpkins. BUT... Kaaz said they could do it in 4 hours!
Is it possible to install stock VLSD and 3.7 gears in an open diff pumpkin in 4 hours?...
Old Mar 27, 2007 | 10:31 PM
rookie's Avatar
I guess if they know what they are doing they can get it done.
Did you get axle stubbs with the vLSD?
Make sure they know they are putting a vLSD into a 3.3 pumpkin because I thought the internal housing was slightly different.
I went from 3.3 to 3.7 and it was a great change. 3.3 is tall as hell with tires that are 30.4" tall oem.
Old Mar 27, 2007 | 10:37 PM
OCG35's Avatar
it's jut the vLSD, nothing else... I'm getting a quote from Perf Nissan for the axle stubs, shims, etc... He knows it's going in 3.3 pumpkin...
I'm anxious to get the gears - the open diff is just getting in the way of the whole project. So I have to incorporate LSD too.
Kaaz makes LSDs so I know they know what they are doing - Just 4 hours seems unrealistic. I'm no expert though... maybe someone that is can chime in - please...
Old Mar 27, 2007 | 10:39 PM
OCG35's Avatar
I just noticed your sig says TT'd FX... I thought FX had 3.7 OEM. And for FI taller gears are better?...
Old Mar 29, 2007 | 01:24 AM
DriftDreamzSS's Avatar
Thats not unrealistic at all. For a shop with power tools it wouldnt take long at all to change out the r&p and swap out the guts.
Old Apr 2, 2007 | 12:26 PM
ISMSOLUTIONS's Avatar
The whole trick is setting up the gear lash properly. So the shim portion is what takes time. 4 hours seems OK for removal and re-install, but not the tear down and re-set...you can't just use the old sums that were there, and you have no idea what sized shims you'll even need, until they are taken apart and measured/mic'd.
There are about 22 sizes of shims to go through, so you can't just guess and order some.
Rick
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
simperformance
Jul 24, 2015 11:17 AM
ANMVQ
Drivetrain
Jul 20, 2015 04:10 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
