Difficult to engage first & reverse gear only when car is running
Old Apr 9, 2007 | 03:06 AM
jonnylaw's Avatar
I'll have fingers crossed for you cloud--So when everything is set you can give me some advice/suggestions/avoidance of pitfalls on installation and break-in procedure .
If the 1st gear shudder gets fixed, overall is the setup just as streetable as the nismo setup you previously had (streetable enough even in traffic), or is that much more agressive all the time?
Old Apr 10, 2007 | 03:14 PM
cloud's Avatar
It as streetable if not better than the nismo if not for the first gear shudder.
You don't get the leg workout the nismo gives you.
Old Apr 10, 2007 | 03:36 PM
twin_snails's Avatar
It's been a little cooler here in dallas lately and I've had the same problems when my car is cold. It's very hard to shift back into first gear. The other morning I was leaving starbucks and I couldn't even get reverse to engage so I had to just let gravity roll me out of my parking spot. I was not too amused. I've taken it to Infiniti before and as usual, they're not able to reproduce the issue. I suspected that a manual trans fluid change would help so I drained the old stuff a few weeks ago and put in Amsoil Synthetic Manual transmission fluid. When the car is warm, shifting is buttery smooth in all gears but it seems to be "cranky" when it's cold and is someone reluctant to shift into first, sometimes second and reverse. Overall, I'm not too happy with the 6mt tranny for those reasons. I feel that I'm wasting my time with Infiniti and it's a lease anyway that gets turned back in in 13 months so I'd rather not screw with it.
Old Apr 10, 2007 | 04:56 PM
cloud's Avatar
well i got stuck at the traffic light today.
Old Oct 28, 2008 | 07:23 PM
gte959s's Avatar
20 Year Member
has anyone ever figured this out??? I have had the same issue getting into reverse when it is cold. Its a biach to get into gear.
Old Oct 20, 2012 | 10:48 PM
Deezflip's Avatar
Originally Posted by cloud
update: Actually its all gears. I thought it was first and last only because you usually shift into those 2 only after a stop.
Anymore ideas?
2007 bump, particularly for this post. Anyone determine the cause of this?
Old Nov 4, 2012 | 11:10 AM
cbrg35's Avatar
It is easy to shift into all gears when the car is turned off but it is hard to shift especially into first and reverse gear when the car is running.
What could be wrong? The clutch line has been bled.
this happened after putting in a new clutch btw
Ive got a stock clutch and tranny and am having the same problem, i think the problem isnt in the clutch but the tansmission. I'm gonna try and flush the transmission and see if the gears lock in better. If a stock clutch and aftermarket clutch have the same problem im thinking its not in the clutch but transmission.
Old Mar 22, 2013 | 12:25 AM
aussie983's Avatar
Any updates on this? I have a stock clutch, and this started happening recently. Feels like I'm hitting a wall when I try to get it into 1st or reverse at a complete stop. Its actually easier to get into 1st at a slow roll. This issue is really starting to get annoying.
Old Mar 26, 2013 | 08:23 PM
cbrg35's Avatar
its not really a fix but i found that if i pull the clutch to me a bit before i start it and while in neutral its fine.
arora_g35
Apr 16, 2026 02:52 PM
chinee
Jun 10, 2024 07:48 PM
yassy
Aug 3, 2015 12:24 AM
ClwMike
Jul 23, 2015 12:55 PM
