Need help ASAP conserning AUTO transmission
Originally Posted by booger
A limp mode is when the ECU see's something wrong enough with the car that it will not let the car rev passed 2500rpms . But it doesnt buck around , it just bogs down the more gas you give it
-sean
Well, took it for about a 15 mile drive and everything seems fine now...checked the transmission fluid, its fine. Still no lights are on in the car...gave it a little gas, but still afraid to floor it...i have no idea what happend last night....?
I think tomarrow im going to take it to the nissan dealership and have them plug it in to see if the car recorded anything.
-sean
-sean
-sean
-sean
Glad things are okay - hopefully.
Could be a vacuum leak or MAF issue. I'd definitely inspect the intake piping of your CAI. Also, CAIs on late model Nissans (02+) have a tendency to wreck MAF sensors, especially in 02-03 VQ35 Maximas.
What kind of spirited driving were you doing before you went to the house? Sounds like a limp mode kinda... My car sometimes clunks into 1st from 3rd or even 2nd at times but I have never had a problem with my 5AT and I run the heck outta her w/ the Vortech. I was thinking about getting the VB upgrade but I dont want to mess up a good thing.
. Im taking it to my guy at nissan today to see if the car recorded anything.-sean
Originally Posted by rcdash
Wow - best of luck - really sounds like a mechanical fault within the transmission. Did you have anything done to it recently? Flush, cooler, etc?
-Sean
Originally Posted by 888_G35
why dont you take it to the guy that installed the supercharger? ask if they have ever heard of anything like that. Good luck!
-sean
sounds like tq converter tried to seize up?
when you went into P and it took a bit to catch
all the delays between shifting from gear to park.
dont know if ecu will record that
hmmmm?
hmmmm?
hmmmm?
hmmmm?
-Sean
