Help: Transmission Problems with my 03 5AT
Old May 16, 2007 | 09:23 PM
j-champaco's Avatar
take it to the dealer - no sense in putting a band aid where you need a cast.
Old May 18, 2007 | 02:52 AM
G35inSD's Avatar
I called my local Infiniti dealership today to see if they would check my AT fluid level and they said it would cost $52 just to check the level.
I was hoping to take it up to West Covina Infiniti this weekend because they seem to be good guys and they have great prices. I cant make it this weekend but will probably have them do a full tranny Flush in the next couple weeks to see if that fixes the problem (only $99 for forum members!).
Anyway, the slipping and wandering is still noticeable. When we first did the drain and fill, it was slightly underfilled. I added fluid a couple times and today I borrowed the dipstick off another G35 and the level was too high so we drained a bit of it. It is now in the middle but still seems to be wandering and slipping slightly. It seems that a lot of people have experienced similar problems but nobody knows why it is happening or how to fix it????????
My G slips and wanders under light steady throttle around 40 and around 70. It also slips significantly every once in a while and the RPM's will increase to almost 6,000 RPM unless I give it more gas and force a clunky downshift. Even weirder... today on the freeway it seemed that the RPM's got stuck on about 3,500 RPM and even dipped down for a moment before increasing again under 1/2 throttle.
Anyone have any suggestions? I am starting to think my tranny is going bad (but it seems odd since I haven't heard of anybody else having to replace or even rebuild their tranny).
cmesidewayz
Sep 29, 2015 09:28 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
socalg35x
Jul 28, 2015 10:42 AM
