Is there a DIY tranny drain/refill?
Old May 23, 2007 | 03:46 PM
slowek04's Avatar
Don't know if this is the right forum to post (nobody is in the DIY forums) but I was searching and can not find it. I want to know where the bolt is to drain the fluid and how many quarts it take for the ATF color to be the same. I know that you need to drain the fluid and keep refilling until the color of the fluid is the same going out as the new fluid going in. Thanks
Old May 23, 2007 | 04:00 PM
Neal376's Avatar
you can disconnect the coolant return line and lead it to a large large bucket.
but you really need two people to flush the system
the drain plug will require a 19mm socket. 4-5 quarts should come out. be sure to jack up the car a lil higher on the drivers side so that you can drain as much fluid as you can
Old May 23, 2007 | 04:21 PM
slowek04's Avatar
thanks for the reply, but is there a DIY tranny drain/refill? pics will be nice too.
Old May 23, 2007 | 06:18 PM
slowek04's Avatar
anyone? I hope that I can do it soon because my tranny is feeling a little sluggish when I put it in Park, Reverse and Drive.
Old May 24, 2007 | 10:05 AM
Castro's Avatar
I've been thinking about doing this myself as well, I'm at 38K miles and it's not as smooth as I'd like, kind of clunks into gear a little when swithching from park to reverse to drive. With my old car I took it to a valvoline shop and had them drain, NOT FLUSH, the transmission fluid. I've heard really bad things about having a shop flush your AT, lots of shavings stirred up and something about the machine they use being contaminated with the last cars dirty fluid.
If anyone has done it themselves please share some details or pics!
Old May 24, 2007 | 12:42 PM
slowek04's Avatar
thanks for the tip on not flushing out the AT. The tranny was smooth when i bought the car but now i feel/hear a little clunk too when going into P, R, D.
Please, anyone?
Old May 24, 2007 | 01:04 PM
HiTechOilCo's Avatar
Please, anyone?
If abnormal wear and tear/damage has already occurred, (as indicated by the noise you are hearing), it is very unlikely that changing the fluid will rectify the noise. Sorry for the bad news. If you want to proceed anyway, make certain your use genuine NISSAN Matic J TRANS fluid, as this is the only approved transmission fluid for your vehicles automatic transmission. If your vehicles automatic transmission is equipped with a filter, make certain your change that too or it can lead to an expensive transmission failure.
Steve
CEO of Hi-Tech Oil Co.
Distributing industry leading AMSOIL synthetic lubricants for 19 years
Old May 24, 2007 | 01:19 PM
.moO^.'s Avatar
clutch fluid = tranny fluid? or different?
What's a good tranny fluid?
Old May 24, 2007 | 01:22 PM
ttrank's Avatar
Grocery getter
Use the nissan stuff.
Old May 24, 2007 | 01:23 PM
Jeff92se's Avatar
Red Card Crew
Depends on how many miles you have on the fluid and the fluid's condition. Also if the fluid is low or high, it can cause the tranny to act odd.
I suggest getting the level properly checked and getting the fluid's condition checked.
If it's been 30K since it's been changed then I suggest:
a) if the fluid is inspected and deemed bad, do full tranny flush with j-matic or equivalent
b) If the fluid is okay, a drain and fill is probably okay.
Please, anyone?
Old May 24, 2007 | 08:41 PM
slowek04's Avatar
Steve
I don't think my tranny is bad. It just has a slight clunking sound SOMETIMES. I don't hear it no more but all I wanted to know is if there IS a DIY tranny drain/refill.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jon81035
Sep 16, 2015 04:58 PM
