The burnout switch mod.
Old Jul 12, 2007 | 06:23 PM
  #31
DaveB's Avatar
OCG35,
Keep us posted if you buy the KP module. I'm curious to know if it will improve the launching ability of the 5AT. I think the general consensus is that when you apply the gas and brake at the same time at a stop in a 5AT car, some of the power is cut to reduce the load on the TC. I have no issues stalling the TC to an appropiate launch rpm, but it seems that when you release the brake, there is still a bit of a bog before the ECU allows full throttle to truely be applied. On surfaces where wheelspin can be generated, the bog isn't as apparent because the wheelspin helps keep the rpms higher. But on a sticky track, my car will hardly chirp a tire and the bog is pretty significant till about 3500rpms and then the car takes off really hard. I can't tell if it's because power is cut for about 1 second even after releasing the brake or if it's variable cam timing or it's a combination of both.
Old Jul 12, 2007 | 06:56 PM
  #32
Otacon132's Avatar
hmmm im kinda confused, i have no problems dumping the clutch at 3,500 and spinning the tires, with the vdc off.....
what exactly is the point of the switch? im not getting why its necessary o_O
Old Jul 12, 2007 | 07:09 PM
  #33
Frostya's Avatar
So you can do a standing burn out and to do a little left foot braking without the ECU cutting your throttle input.
Old Jul 12, 2007 | 07:38 PM
  #34
redlude97's Avatar
Originally Posted by DaveB
OCG35,
couldn't you pull the fuse to find out? its my understanding that it does the same thing, but still allows the tailights to work
Old Jul 14, 2007 | 07:52 PM
  #35
OCG35's Avatar
its for AT not MT
  #36
OCG35's Avatar
OCG35,
10-4
Old Dec 10, 2007 | 02:28 AM
  #37
Godzilla35's Avatar
any update on the KP module... i keep checking his site, but i dont see anything..
Old Dec 10, 2007 | 06:59 PM
  #38
OCG35's Avatar
They can’t do it… it was posted in another thread somewhere else… ran into ancillary problems… I have a source that is checking with Uprev to see if they can do something…
It hasn’t been on many lists of priority
Old Dec 10, 2007 | 07:53 PM
  #39
FI'ed G's Avatar
Does this also disable the break lights? I know the easier way is just pull the fuse on the strip but that disable your break lights.... no-no on the street.
By the way the KP module is dead.
Old Dec 10, 2007 | 11:11 PM
  #40
GrayG35's Avatar
whats the stall speed on a stock 5at??
Old Dec 11, 2007 | 11:47 AM
  #41
DaveB's Avatar
About 2800rpms or so, but the tires will break loose before you can reach it.
I figured out that doing a burnout is quite easy if you simply disconnect the yaw sensor near the shifter. I can pop off the console and disconnect the sensor in about 1 minute. Burnouts, though I really don't see the point, are cake now. Launching ability doesn't seem any better though. I'll try it at the track and see what happens. When you disconnect the sensor, the SLIP and VDC lights will come on, but ABS will still be active.
Old Dec 12, 2007 | 01:07 PM
  #42
GrayG35's Avatar
ya i agree that theres no point to doing a stand still burnout unless you have dr's or slicks but i think it might help on the 60ft at the track because you wont bog off the line if you stall it. I need to try this at the track and see if i get better times with this mod or if it stays the same. if anyone goes before me let us know!
Old Dec 12, 2007 | 03:13 PM
  #43
Godzilla35's Avatar
see, thing is, i brake torque at the track [i'm still a newbie though]... and i find that my toyo's t1r's hook up almost TOO well... i feel like if i can warm them up to slip a little bit... it might not bog the tranny down when i just hit the gas... instead of brake torquing... am i making any sense? i'm burnt out from studying for finals, lol
Old Dec 12, 2007 | 04:56 PM
  #44
KPierson's Avatar
The KPtech module worked great on all the 6MT vehicles that tested it, but didn't fare well on 5ats.
If the ECU doesn't see a brake signal at least once in X amount of miles it will throw a code, and disable the cruise control. By cutting the pin right at the ECU only the ECU will miss the signal - the brake lights will still work.
On the 5AT vehicle, even though it was proved to be working (through Cypher) the tester was still not able to do standing burn outs. We came to the conclusion that there was something going on with the torque converter that was not allowing higher no load RPMs. Beyond the modification not really doing what we had hoped on the 5AT it also caused some strange behavior with the cruise control system and the turn signals.
Because we didn't have a wide selection of 5AT vehicles to test on locally we decided that it wasn't worth the headache of selling a small demand product that we weren't 100% comfortable with.
Old May 30, 2013 | 10:01 AM
  #45
private_numero's Avatar
Bump this topic. It was a good read.
Dallsinghjr1
Sep 17, 2023 11:25 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
RWDguy4238
Sep 30, 2015 12:13 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
