what to use in my 03 6mt, and diff... can i use the same stuff???
Old Jun 22, 2007 | 01:53 AM
iJeff's Avatar
I have 4 qts or Royal Purple 75-90, and im wondering if i should put that in the tranny or what to do, seems like some are putting differant stuff, in the differantial (I have the VLSD)... am i good just using royal purple 75-90 in the tranny and diff? or should i use differant stuff
Old Jun 22, 2007 | 11:35 AM
GT-Ron's Avatar
You can use different or the same, providing they meet the requirements.
My '05 6MT didn't seem to like Royal Purple at all. It resulted in the worst feel/operation I've encountered with my G. While the OEM stuff doesn't seem to stay extremely effective for long periods of time, putting the OEM fluid back into the 6MT got rid of the notchiness/near grind that was present before the change. The Royal Purple made it even worse. I changed back after a day.
I used Lucas Oil in the diff. Seems to be just fine. Store didn't have enough Lucas Oil for me to use in the 6MT. Some like it, some don't, for 6MT use.
Old Jun 22, 2007 | 11:40 AM
Hi-TechG35's Avatar
Valvoline Synthetic FTW!
Old Jun 22, 2007 | 01:56 PM
iJeff's Avatar
im running royal purple for motor oil and i love it. but why is there max-gear oil bad? I have 75W-90 but the manual says 75W-80, does it matter whether I use 75W90 vs. 75W-80? I live in washington state.
the oil says it has a limited slip additive in it, and it says meets requirements of API GL-4 and GL-5. it says great for manual transmissions requiring gl-4 or gl-5 fluids. then it also says meets requirements of MIL-L-2105E.
it says to increase horespower through drive train, maxium gear life, shock load protection, cooler gearbox temps, saves fuel.
I know royal purple makes good stuff, so basically should i use the same stuff in both my transmission and differential??? and what weight should i use. thanks
Old Jun 22, 2007 | 10:51 PM
iJeff's Avatar
anyone please help ASAP cuz i wanna change it tonight! thanks
Old Jun 25, 2007 | 12:09 AM
iJeff's Avatar
BUMMMP.. PLEASE!!! i need to know it this stuff is ok for both?
Old Jun 25, 2007 | 03:27 AM
nghiars's Avatar
i hear that GM's tranny oil is really good..
Old Jun 27, 2007 | 02:18 AM
iJeff's Avatar
ok found out i can get lucas 75w-90 synthetic oil.... which would you reccomend??? can i use the lucas in both differential and tranny?
Old Jun 27, 2007 | 08:46 PM
dovla's Avatar
I used Motylgear 75W-90 for both.
Old Jun 27, 2007 | 11:13 PM
Jining's Avatar
I believe you need GL-4 for the transmission, as GL-5 has some sulfur additive that can corrode the gears. GL-5 for the rear diff.
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
Learned Hand
Oct 1, 2015 09:02 AM
RWDguy4238
Sep 30, 2015 12:13 AM
