Nismo Pilot Bearing discussion...
Old Aug 2, 2007 | 09:20 AM
Dieselnuts's Avatar
I am about to have a JWT clutch and flywheel installed in my G35. I ordered the Nismo Pilot bearing to be installed also. I was wondering if anyone has experience with the Nismo bearing. Is there any significant advantage having this roller bearing vs. the factory one piece part?
Old Aug 2, 2007 | 12:09 PM
jonnylaw's Avatar
I have one but didn't install it when I replaced my clutch and flwheel. A tech told me the stock one will long outlast the clutch and flywheel
Old Aug 2, 2007 | 07:07 PM
Jason@Riverside's Avatar
you should change the CrankShaft Pilot Bushing when ever you change your flywheel out...
Its a 5$ part... no reason to not change it rather then do the $500+ in labor again...
As far as a NISMO ROLLER Bushing... Not sure what good it will do on the VQ... Most people just go with stock...
Old Aug 2, 2007 | 10:22 PM
Dieselnuts's Avatar
Well yeah, its def. getting changed. I just didnt know if I should use the pilot bushing that comes with the clutch kit or the Nismo one. Since it has moving parts, its obviously more likely to go bad. I just dont know I dont want to have to spend $400 to replace a $20 part by using the Nismo piece over factory...
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
AL8782
Oct 3, 2015 10:26 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
