how to disable YAW sensor???
Old Sep 26, 2007 | 12:36 AM
atownpdx's Avatar
a while back I had my 05 coupe 6MT at the track. Obviously I turned off the VDC before going out on the track, but....
- When getting very hot into corners with my foot hard into the gas, the car would start applying the brakes systematically all by itself (my foot wasn't even on the brake pedal), it almost felt like the ABS was activating.
After i got back into the pits, I asked this guy who had a 350Z if he knew anything about these symptoms. He did and explained though I had the VDC off the car still enables a YAW sensor which balances the car in unstable situations. He showed me the interior of his car and the switch he installed in the center console to turn the YAW sensor off and on.
Does anyone have any instructions/input or way I can identify where exactly the YAW sensor is in my car and how to wire a switch into it cleanly?
Thanks,
Old Sep 26, 2007 | 01:10 AM
hai109's Avatar
http://www.my350z.com/forum/showthre...ht=disable+VDC
This is your lucky day...
Old Sep 28, 2007 | 03:51 PM
EricIsKlumzyee's Avatar
"Speedo does not work,
Odometer does not work,"
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
happydays888888
Oct 6, 2015 06:04 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
