transmission fill
Old Feb 10, 2004 | 11:06 AM
theskipps's Avatar
transmission fill
I wanted to ask if anyone could tell me if there is a stick to check the transmission fluid,and where is it put in .
Thanks
Old Feb 10, 2004 | 12:07 PM
cato's Avatar
SouthernComfort Moderator
Re: transmission fill
The answer is no. The tranny filler tube is located at the
back of the engine next to the firewall on the passenger side.
If you want to check the fluid level, Infiniti asks that you go to
your friendly dealership. It does not make sense, does it?
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Feb 10, 2004 | 01:21 PM
socalmmr's Avatar
G35 Coupe w/ K&N CAI
I have an original release G35 Coupe, & it DOES have the tranny dip stick, as I have taken it out & seen it for myself. There has been discussion about this on the boards before, some cars seem to just have the cap & no stick. You do have to remove the plastic cover from the engine, then unscrew the cap, which is located at the rear, more towards the passenger side of the engine. The catch is the Type J fluid it uses is NOT standard & they do not want you going to Pep Boys, buying just ANY ATF & ruining the tranny, so they keep it WELL hidden. Apparently very few ATF fluids meet the Type J standard.
SoCalMMR
Old Feb 10, 2004 | 01:39 PM
lead_foot's Avatar
I have a 2003.5 Sedan, and I also have the dipstick. Not easy to get to though.
'03 AT Sedan | Silver/Willow | Sport | Premium | Aerokit w/Spoiler | Nav | Injen CAI | UR Pulley | Tein Flex w/EDFC | Stillen Rotors | Cusco Sways | TS ECU | Stillen Exhaust
Old Feb 10, 2004 | 02:22 PM
weslutes's Avatar
Yes, the dipstick is behind the motor on the passenger side.There is a screw on the side holding it in place.I flushed & replaced with synthetic Mobil AT fluid along with the diff fluid last week at 21000 miles
Dark Side Of The Moon
Old Feb 10, 2004 | 03:26 PM
Gordgee's Avatar
Administrator
Be careful with the AT fluids. Infiniti has grounds to non-warrant your Tranny if something goes wrong!
<font color=green>GroundingGear™ Equipped </font color=green>
Old Feb 10, 2004 | 03:28 PM
DaveO's Avatar
American AT G35s (and 350Zs) with serial numbers up to 099999 don't have an AT dipstick. AT cars with serial numbers above 300001 should come with the "Gauge, Oil". I believe all the Canadian AT cars have an AT dipstick. The Canadian part number is 31086-CD100... it may now be the same number in the U.S.
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Feb 10, 2004 | 03:54 PM
cato's Avatar
If you put in something other than the Nissan JMatic fluid, I think your
AT will be out of warranty and stands a good chance of failing! Let
us know how it works. I looked into putting synthetic AT fluid, but
Nissan/Infiniti say ours demands the J type, only from Nissan.
Old Feb 10, 2004 | 06:12 PM
Gordgee's Avatar
Administrator
<hr></blockquote>
My early model Canadian G didn't have the dipstick.[img]/w3timages/icons/frown.gif[/img]
Old Feb 10, 2004 | 06:26 PM
socalmmr's Avatar
Yes, be careful about this. I have also researched changing the fluids in the AT, as I tend to prefer high grade synthetics, however the Type J is supposed to be a special type of synthetic already. ANY other tranny fluid will automatically void the warranty, well stated by Infiniti, & can ruin the tranny. If you have a failure they will even send the fluid out to a lab to verify if it is their fluid or not, that is how serious they take the issue. Now I am not trying to say something else will not work, truth is, I do not know for sure. I have tried & tried to do research on the subject & seem to always come up empty handed. However, the one thing I DO know, is that if Infiniti has a tranny problem & they suspect something, they WILL test the fluid to see if it is theirs or not & if not, they will deny warranty coverage. Obviously they really do not care about motor oil, so for the moment, I have gone with the presumption that there must be something different about the type J fluid. Hell, they even went as far as to hide the filler tube so that service station guys would not top it off, & they even bolted it down.
I wish you luck.....
SoCalMMR
Old Feb 10, 2004 | 08:15 PM
Gordgee's Avatar
Administrator
Yes, that's exactly what I heard as well. They WILL do an analysis and even a miniscule amount of foreign fluid in the mix will void the warranty on the tranny.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
