Shift knob removal possible damage
Old Oct 10, 2007 | 04:17 PM
EvolutionGSR's Avatar
Shift **** removal possible damage
Here on the forum I've read about how you are supposed to remove a shift **** to minimize the risk of damaging certain tranny parts. I did follow the under the boot vice and twist the **** procedure, but at times I would have the vice slip off. I wanted to know how you could tell if any damage was done in the **** removal process if my vice grip slipped a few times. What part is this that gets damaged? Car seems to be driving ok, but there are some vibrations I didn't notice before I changed the ****.
Thanks.
Old Oct 10, 2007 | 04:19 PM
g35rcr's Avatar
you didnt damage anything...people are just super sensitive
Old Oct 10, 2007 | 04:24 PM
dofu's Avatar
20 Year Member
If you damage anything, you'd damage the leather on the shift **** itself.
The vibration is most likely from the little metal ring towards the top of the shifter. I wrapped it with electric tape so there isn't metal touching metal, and to give it less space to move around, then I taped it down.
Old Oct 10, 2007 | 04:25 PM
That was also what I was wondering right after i made my post. Has anyone actually had any documented damage to their cars after "improperly" removing a shift ****? I'm sure if someone did there would have been a frantic post about it. Anyone out there break something when removing a shift ****? If anyone was to break something while DIY, its gonna be me...and everything seems ok.
Old Oct 10, 2007 | 04:28 PM
Vibration isn't coming from the ****, I have the project Mu **** installed so i'm not using the metal ring. sounds like its somewhere under the radio. I'm sure its nothing my car makes lots of noises.
Old Oct 10, 2007 | 04:33 PM
gary c's Avatar
Isn't the OEM thred locker fun.........?
I'll take it for granted you're not refering to the 5 AT shift ****. With the stick
shift you need to use vice-grips top and bottom. The thred locker the factory
uses is damn good stuff so you might have a buddy hold the bottom while you
swing on the top........don't give up, it will loosen.....vice-grips are the key!
Old Oct 10, 2007 | 04:48 PM
I already have the **** removed, I guess now my question is, is there anyone out there that actually knows of anyone who did damage their tranny somehow by removing the ****?
Old Oct 11, 2007 | 10:45 PM
Still2Slow's Avatar
i had to get someone else to hold the bottom part with chanel locks and counter torque while I did the top part. It was pretty tuff to remove. i doubt you damaged anything if it just slipped. if you kept turning then you might have.
Old Oct 13, 2007 | 11:26 PM
Skyline_G35's Avatar
English dude, English
Ok, you guys are making me worried. I've removed my shift **** just by grabbing it by hand and turning it counter clockwise until it came off. How could you damage your tranny by taking a **** off?
Old Oct 13, 2007 | 11:33 PM
express705's Avatar
i dont think it would do any damage..unless your yanking on it..
Old Oct 14, 2007 | 06:27 PM
Still2Slow's Avatar
Old Oct 14, 2007 | 06:43 PM
TIAN's Avatar
Hold The Line
I just bought one yesterday. I havent gotten it yet but I plan on doing so as soon as I recieve it. I didnt realize how much effort it takes just to remove it. Wouldnt a torque wrech tear or scrape the shift lever? And what rings do you guys speak of??
Old Oct 14, 2007 | 09:08 PM
Still2Slow's Avatar
You don't need a torque wrench, I was just speaking as to how you needed to counter the force of twisting off the shift **** and having someone else hold the bottom part still while you turn the top really helps. Check out the tutorial on 350Ztech.
Old Oct 14, 2007 | 09:51 PM
TIAN's Avatar
Hold The Line
Ah, Ok I got ya. Thanks... Oh yeah whats are these rings people speak of?
Old Oct 15, 2007 | 03:25 AM
I scraped my shift lever when i was taking mine off. I can still shift =).
Anyway...still no one out there that has confirmed any actual damage to anyones tranny from an improper removal?
