Shifting: clutch to floor?
Old Oct 15, 2007 | 03:54 PM
frosticlez's Avatar
I found that since the clutch engages so far back, its like you dont have to put the clutch to the floor for every shift. I put the clutch down about 2/3 down, and then lift out. Doing this makes the shifts faster and smoother. Is this bad for my clutch?
Old Oct 15, 2007 | 04:04 PM
Eagles1227's Avatar
I dont believe so, I think you may have found the engageing point. But correct me if Im wrong.
Thanks!
Old Oct 15, 2007 | 04:10 PM
redlude97's Avatar
It may or may not be depending on your engagment point. Estimating where 2/3's of the way is is going to get you into trouble over time. Instead, make a clutch pedal limiting spacer to limit pedal travel to a defined amount that is past the disengagement point. There is a DIY which will basically allow you to do what you are doing but in a more reproduceable manner. https://g35driver.com/forums/engine-drivetrain-forced-induction-diy/168519-diy-clutch-pedal-remedy.html
Old Oct 15, 2007 | 04:13 PM
Yv12345vY's Avatar
It's a great DIY too!
Old Oct 15, 2007 | 04:16 PM
KapVu's Avatar
^^^ huh???
I have no clue what you guys said and that other thread I don't get what it exactly does.
I too don't push the clutch all the way to the floor but about half way (or 2/3's i don't know) where I can throw my shifts smoothly and when I let up on the clutch, it engages. I'm pretty sure I found the engagement point.
Old Oct 15, 2007 | 04:31 PM
kvangil's Avatar
I just do what comes natural. After driving manual for so long, it's 2nd-nature. So yes, normal driving, the clutch hardly ever goes all the way to the floor. Mostly only when I'm engaging 1st and reverse....
Old Oct 15, 2007 | 04:38 PM
tinman143's Avatar
Originally Posted by KapVu
^^^ huh???
why involve the guessing game when it's a simple DIY
...and cheapest
Old Oct 15, 2007 | 04:46 PM
redlude97's Avatar
^^^ huh???
The DIY shows you how to add a spacer, so it reaches a stop point at ~2/3's of the normal clutch travel. Then there is no guessing involved. If you look at the clutch pedal assembly for 30 seconds you would understand how this works
Old Oct 15, 2007 | 05:10 PM
kenchan's Avatar
i noticed on my 04 that although full engagement occurs at about 1/2
clutch-out, the clutch progressively engages from about 1/4 off the
floor. it just requires more pedal movement vs some other cars.
i clutch-in to the floor or very close to it. otherwise the gear box
wants to grind some times.
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
jbmw002
Sep 10, 2015 12:54 AM
