Transmission Fluid Question
Old Oct 17, 2007 | 07:42 PM
Gurveer's Avatar
How much fluid goes into the 2006 6MT tranny?
Thanks.
Old Oct 17, 2007 | 07:58 PM
Gtoyz's Avatar
Owners Manuel!!!
Old Oct 17, 2007 | 08:33 PM
SILVERSURFERG35's Avatar
I am so tired of when someone comes on here and asks a question some smart a** ***** F**ker has some smart a** comment !!!! If you don't know the answer then keep it movin !!! The time you spent typing "Owners Manuel " you could have just answered the question !!!
Old Oct 17, 2007 | 09:25 PM
Deezflip's Avatar
i recently changed mine on an 03, but 6mt should be all the same. I think it's about 3.5 quarts, but i definitely bought 4 quarts and i had about half a quart left.
Do a search, someone has the exact amount somewhere. Also, you'll find some brands that seems to be better than others. Our transmission tends to be picky sometimes.
Old Oct 17, 2007 | 11:52 PM
When I got my clutch and flywheel done it took the exact same amount....3.5 quarts !!! Deezflip.....I think that was the answer he was looking for !! Thank you for not being a D*CKHEAD !!!
Old Oct 18, 2007 | 08:22 AM
daveblank's Avatar
As per the service manual it's 3.75qts.
Old Oct 18, 2007 | 11:34 PM
Still2Slow's Avatar
till it starts to overflow, then let it drain out. ^sounds about right.
Old Oct 19, 2007 | 02:47 PM
slobo7x's Avatar
His answer was a wise one, as you can't be sure if there are differences between years. So if he head said 3.2 quarts, and his owner manual states more he would be low.. What I'm tired of is people who post about other people's smart remarkings, without answering the original question.
Old Oct 20, 2007 | 09:44 PM
CBRworm's Avatar
20 Year Member
What fluid works well? I Put in Mobil 1 75-90 and it won't shift when cold.
Old Oct 21, 2007 | 05:42 PM
Still2Slow's Avatar
^ Better hope that's a GL4 oil and not a GL5, otherwise you'll **** your transmission.
Old Oct 21, 2007 | 08:00 PM
If he would have said 3.2 quarts I would have corrected him ! If you would have read further you would have seen that my answer was 3.5 quarts !! Finish reading before you give you expert answers slobo7x !!!!! Fill until it overflows is correct !!!
Old Oct 21, 2007 | 09:36 PM
slobo7x's Avatar
Yes but your initial answer wasn't helpful..
All is well.
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
newg37
Jul 26, 2015 09:32 AM
mushu
Jul 15, 2015 03:55 PM
