What transmission fluid are you using in the G35 6MT?
Old Dec 28, 2007 | 01:17 PM
kingrukus's Avatar
What transmission fluid are you using in the G35 6MT? Is GL4 or GL 5 required? What weight? Synthetic or conventional? Also what is the recommended change interval on them? Is there a DIY thread out there on how to change?
I did a search, but it did not yield much relevant info...
Thanks.
Old Dec 28, 2007 | 01:22 PM
kingrukus's Avatar
I found a DIY here:
http://www.350z-tech.com/zwiki/Manua...id_Replacement
Old Dec 28, 2007 | 01:25 PM
kingrukus's Avatar
Further research shows that we need 3.75L of oil, 75w90 GL4 grade. Please advise if I am incorrect. Thanks
Old Dec 28, 2007 | 01:48 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
yup..you r correct.
i use straight redline MT-90 and replace every 15,000 miles. like the link u posted some like to do half/half of MT-90 and MTL
replacing the fluids is a very easy task. just as easy as doing an oil change...except of course the special tool you need to add the fluid.
Old Dec 28, 2007 | 02:56 PM
kingrukus's Avatar
How much does this special tool cost to add the fluid? Why can't I simply use a piece of flexible tubing and a funnel to add the fluid?
Anyhow I believe I will be going with the following:
Amsoil MTG 75w90 GL-4 for the transmission (going to buy 4 quarts):
Amsoil Gear Lube 80W90 GL-5 for differential (going to buy 2 quarts):
Old Dec 28, 2007 | 03:43 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
amsoil is also a great product to use.
the top of the transmission isn't as easily accessible as you might think. if your funnel has a really long, flexible tube, it might work, but you're not gonna have fun.
i use a custom peristaltic pump and some tubing.
you can go to any car parts store to pick up the tool you'll need to add the fluids
Old Dec 28, 2007 | 06:13 PM
RBull's Avatar
Rated M
Amsoil is a great choice.
As for the "tool" it's actually a small pump. Go to a place like Napa, tell them what you want to do and they will sell you a $5-10 pump to be able get the fluid in. You can't do it with gravity because the container/hose can't get up high enough. It's a messy job but worth doing.
The rear diff is much more critical if has not been done before. You can do it with the hose/container.
Old Jan 3, 2008 | 07:48 PM
JZ39's Avatar
Genuine nissan MTF comes with a little squirter on the end of each bottle allowing you to fill easisly.
Old Jan 3, 2008 | 09:28 PM
g35ctuner's Avatar
how much is it?
Old Jan 15, 2008 | 03:50 PM
GreenGoblin's Avatar
The goblin resurrection
royal puple also has a nipple top
Old Jan 15, 2008 | 03:56 PM
kingrukus's Avatar
I just completed the differential fluid flush on Sunday with the Amsoil AGL 80w90. I hope to do the transmission fluid next weekend.
Old Jan 15, 2008 | 08:23 PM
1FAST04G's Avatar
Just put in straight redline mt-90 2 days ago, and love it! trany was hard to shift into 2nd cold now its no problem at all!
Old Jan 16, 2008 | 11:31 AM
Hotnikks's Avatar
That's good to hear 1fast as I have the same problem. I'll be sure to change my fluid. I have amsoil like the op I hope I get the same result. Stupid dealers keep telling me I'm grinding 2nd in the cold because I need a clutch! I say bullsh**. I only have 40k
Old Jan 16, 2008 | 06:03 PM
DrrSeuss's Avatar
Using regular Nissan fluids.
Old Jan 16, 2008 | 11:05 PM
Texasscout's Avatar
Look at WalMart in the "Automotive" section, you will find a little "Hand Oil Pump" It costs less than ten dollars and will screw right on the quart bottles of tranny fluid. I just changed mine with all Castrol synthetic 75W90 and Royal Purple in the Diff.
