Changing My Clutch On Saturday
Old Jan 2, 2008 | 07:13 PM
lookthatsme's Avatar
hey guys im changing my clutch this Saturday I went with the Competition Clutch stage 4 6 puck. I searched and got no results. I was wondering if anybody could tell me the torque specs on the clutch and flywheel? (meaning the bolts/screws) Is there anything else I should pay attention to? Also is it ok to run brake fluid with the clutch or do i need clutch fluid? any info/advice would be great
Old Jan 3, 2008 | 09:37 PM
g35ctuner's Avatar
use regular brake fluid, and take pics.
Old Jan 5, 2008 | 10:07 AM
olgunan's Avatar
while you are in there i would change the pivot pin on the fork too.....mine just broke and now i have to rip the tranny out again and replace the pin after doing this 5 months ago to change the clutch.....$12 part worth the money but not the time!!!!
Old Jan 6, 2008 | 01:10 AM
i have that already and changing the pilot bushing too will be a good idea too... ill post the DIY soon since i got it of a 350z forum i might as well post it here to be available to the G's and not search all over the place; write up, torque specs and the whole nine yards
Old Jan 6, 2008 | 11:02 AM
Texasscout's Avatar
TNX that would be great!
Old Jan 6, 2008 | 01:27 PM
g35ctuner's Avatar
welp, its sunday, whats the dillyo?
Old Jan 7, 2008 | 02:33 PM
its done. ill have the write up asap. also if anybody needs and info on how to remove something and install it back with pics and torque specs on let me know i have access to alldata (pretty much i know what the dealers know)
Old Jan 7, 2008 | 02:35 PM
redlude97's Avatar
did you replace the flywheel or leave it stock? Resurface? How many miles did you have on it?
Old Jan 10, 2008 | 07:33 PM
alright the DIY is done ill have it posted just have to double check everything and i post the link
Old Jan 10, 2008 | 08:03 PM
I contacted the dealership and resurfacing the flywheel is not an option. It comes aluminum from the factory so its either you change or leave it and yes i did change it
Old Jan 10, 2008 | 08:05 PM
redlude97's Avatar
How many miles did you have on it and did you replace it with a stock flywheel?
Old Jan 10, 2008 | 08:28 PM
i believe 39,874, no i went with the jwt. The flywheel was still good just figured since im in there already i might as well change it
Old Jan 10, 2008 | 08:37 PM
just in case anyone was wondering heres the link to the write up. If it dont work that means its been moved and just search my name in (advanced search)
https://g35driver.com/forums/showthr...00#post2593300
Old Apr 20, 2008 | 09:25 PM
prjoker's Avatar
the nismo flywheel torque spes are 61-69 lbs in a star pattern
Old Apr 29, 2008 | 02:40 PM
abercrombie333's Avatar
hey can u provide me with the pics and info i need to change mine!
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
SFG_35
Northern California
Aug 11, 2015 07:41 PM
D1dphresh
Aug 7, 2015 06:10 PM
