Problem with Cruise Control, anyone?
Old Mar 9, 2004 | 10:28 AM
m500's Avatar
My cruise control sometime will not engage when I press on. Its simply just won't lite up in the dash. But it'll somehow back to work again in a couple start up during the day. Anyone experience this? Is this a known issue ?
~ GT-R the Ultimate Driving Machine ~
- 2004 G35 Ivory Pearl/Black Leather
- Auto/Nav/Premium/Sports/Aero
- 6 wire grounding kit
Old Mar 9, 2004 | 10:51 AM
ryoken's Avatar
Re: Problem with Cruise Control, anyone?
Never experienced or even heard of that one.
Will it not set a cruise speed, or are you saying you can't even turn the system on?
Might want to call your service advisor and schedule an appointment to have them check it out.
Old Mar 9, 2004 | 10:54 AM
m500's Avatar
I simply just can not turn it on all day and just before I got my service appointment confirm late the same day. It started to work again.
Old Mar 9, 2004 | 10:56 AM
ryoken's Avatar
Isn't that always how it goes?
Old Mar 9, 2004 | 02:04 PM
weslutes's Avatar
Always.
Honestly, I haven't even used the cruise controll & I bought my car in Dec of 2002. Need to plan more road trips I guess.How often do you guys use your cruise controll? A member was working on making a relay switch for the shifter so you can shift with the cruise controll up & down
Dark Side Of The Moon
Old Mar 9, 2004 | 07:56 PM
Meatshackle's Avatar
Deep Sea Moderator
The only time mine won't work is when I'm above 90mph.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Mar 9, 2004 | 07:58 PM
ryoken's Avatar
I believe it's programmed not to allow you to set a speed above 90. Not safe to use cruise when you're doing that, anyway. [img]/w3timages/icons/smile.gif[/img]
Old Mar 9, 2004 | 10:51 PM
g35girl's Avatar
Unimaginative, Indecisive User
m500... i do remember reading a thread from a while ago about someone having cruise control problems. here, try this link. i had it saved in case my cruise control went on the fritz.
<font color=purple>.g35girl.</font color=purple>
Old Mar 10, 2004 | 09:47 AM
tonke73's Avatar
The only problem I have w/ cruise control is the crappy bulb they put in the dash. You can barely see it in the daytime. It works fine otherwise.
Hasanbaloch
Feb 29, 2024 08:45 PM
derres
Aug 28, 2015 03:27 PM
Terry_G35
Aug 4, 2015 02:38 PM
CrazyLogic219
SouthEast
Jul 15, 2015 02:35 PM
