P1716 code. Tranny
Old Jan 23, 2008 | 02:46 PM
Jeff92se's Avatar
Red Card Crew
P1716 code. Tranny
I got this P1716 on my OBDII reader but no check engine light. I search here only got me to the TSB below. But I don't notice any harsh or erratic shifts.
Anyone else run into this code? The manual says this code is a Turbine revolution sensor. It monitors the input shaft speed (RPM). The manual describes how to check but you need a consult II to do it. (Dealer only)
I went ahead and cleared it and will check again if it comes up. If it comes up, I'll have to take a chance and replace that sensor (If I can even get to it) or bring it to to the dealer and bend over.
Service Bulletin Num : 02074 Date of Bulletin: DEC 03, 2002
Type: Coupe and Sedan
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary: AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1710 AND P1716 STORED. *TT
If: an applied 2003 G35 has a harsh or erratic shift from the Automatic Transmission after it is warmed up, use this bulletin to determine if the Transmission Control Module (TCM) needs to
be replaced.
Old Jan 23, 2008 | 06:26 PM
Q45tech's Avatar
Consult II are not dealer only items we have 3, just that the $6,500 [each] price tags put off the non Professionals.
Hopefully one can understand why many charge for using them [diagnostic fee].
Old Jan 23, 2008 | 06:30 PM
Jeff92se's Avatar
Red Card Crew
Not that this really answers my question in anyway but from my experience, most don't even go to the trouble to actually do all the diagnostic tests to determine if the part related to the code is actually bad or if something else is actually causing that code.
For dealers, it's faster and more profitable just to replace parts and hope it fixes it. If not, the customer comes back and they try another, then another, then another until the problem goes away.
Old Jan 23, 2008 | 06:34 PM
Jeff92se's Avatar
Red Card Crew
Anyway, here is the diagnostic TSB that I was referring to. Similar but not exact as this TSB seems to require the other code P1710 to accompany it. Which I didn't have
http://www.210vq.com/FSM/INFINITI/g3...b/AT/1RB34.pdf
Interesting thing is the TCM p/n. 31036-AL000. I could swear that was also similar to the reflash revision from the dealer
Found it:
FYI. The latest software part number for your ECM/TCM is 23710-AM604. It made a vast improvement over the previous upgrade (31036-AL004 program) I had done in early 2004. This program improves the A/Ts response in early model Sedans that are equipped with the in-cabin mounted TCM. It doesn't change the way the transmission works. Manual mode is still a top gear limiter and must be manually downshifted. Also there's no rev matching.
Old Jan 26, 2008 | 08:35 AM
OCG35's Avatar
PRECISELY!!!!! I had a bad tps and told them so when I took it in the first time... I even said I have a feeling its the right rear tps... took it back FOUR times!!!!! All with the consult, they first said, after market tires + climate changes made tire pressure off... I argued with them about how/why that is BS (won’t go into details) but let them (over) inflate = 20 miles later tps came on, then they said the tps' just need to be reset = 20 miles later tps light comes on, then they said it's the sending unit (replaced) = 20 miles later tps light comes on... FOURTH f-ing trip, guess what - they determined the right rear tps was faulty and replaced it.
Old Jan 26, 2008 | 12:23 PM
Q45tech's Avatar
Don't assume that the average dealer technican is an expert on complicated new electronics or software.
Dealers are lucky to have 1 competent certified by Infiniti Master Technican and he may be 2-3 years obsolete in training updates.
Start talking software or electronic internals and they run away because the are not electronic engineers.
Old Jan 26, 2008 | 03:46 PM
OCG35's Avatar
more so I think Jeff is correct... they take the easy guess then inconvenience you till they have to truly diagnose. At least that has been my experience... not just with the tps... but you are right, once I get a tech I trust and am confident in, I request him every time - the best one I had isn’t there anymore...
Old Mar 15, 2011 | 04:21 AM
NTHBUT_A_G's Avatar
i have the same issue with my 03 sedan, a local tranmission guy told me its going to cost 2k to get the sensor replace? is that really the only option?
Freeman186
Sep 6, 2023 10:07 AM
seagrasser
May 3, 2022 09:43 AM
06g35
Feb 14, 2022 05:59 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
vamarris
Sep 26, 2015 12:56 PM
