Will a 2005 transmission work in a 2003?
Old Jan 25, 2008 | 05:23 PM
Nismo G's Avatar
Whats going on guys? Does anyone know if a transmission from a 2005 will work in a 2003? I know they added rev matching to one of the newer years, but not sure exactly what year...let me know.
-Sean
Old Jan 25, 2008 | 09:35 PM
Deezflip's Avatar
+1 i want to know this too
...i'm thinking it'll bolt right up with no problems, but maybe some electronic issues, such as VDC, ABS, maybe even the speed sensors? That's just my wild guess.
Old Jan 26, 2008 | 12:04 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
You guys have different transmission types listed in your sigs.
For 6mt, should be an easy swap.
For 5AT, I think the newer years have the TCU somewhere in the transmission unit. Not 100% sure, but I remember that there's some changes, and I'm inclined to say that you can't do a straight swap.
Old Jan 26, 2008 | 12:28 PM
Nismo G's Avatar
bump! Anyone with an answer?
-Sean
Old Jan 26, 2008 | 02:43 PM
AGThing1227's Avatar
-Sean
SEACRH MAN, come on! haha just kidding. I cannot find the answer either. I would also like to know. Maybe put a pm into jason a riverside. But only sean because I don't think jason would appreciate 5 of the same questions. If you get the answer post up here. I really was kidding about the search, I know you search and get tired of people posting the same 5 questions, just like me
-AGThing1227
Old Jan 27, 2008 | 08:59 PM
Nismo G's Avatar
Bump! Need to know. Thanks!
-Sean
Old Jan 27, 2008 | 10:07 PM
DaveB's Avatar
Won't work. You need the tranny and the tranny TCM and I highly doubt the 2003 engine ECU harness to TCM match that of the 05+ TCM.
Old Jan 28, 2008 | 05:49 AM
Nismo G's Avatar
Originally Posted by HomieG35
Agreed. I think several things changed between '03 and '05 as far as how the tranny acts within the computer realm of it (for the 5AT). I don't even think the '04 would work... (ie, "rev limit" / starting in, what is it, 4th gear, not 1st when switched from auto to mm / shifting for you / etc.)
I was unaware that the 03-04 transmissions were different...what do you mean "rev limit"? I know the rev limiter on the 03's and 04's are the same.
-Sean
Old Jan 28, 2008 | 11:27 AM
Nismo G's Avatar
Yeah, I think I was trying to get out that the '03 will shift for you, unlike the 04+ that will just bounce off the rev limiter in MM. Sorry
What do you mean the 04 bounces off the rev limiter and wont let you shift? The 03 bounces off the rev limiter as well, but when it bounces it goes below 6700RPMs and then shifts. Do you mean the 04 wont shift unless you let off the gas? Sounds ECU related...
-Sean
Old Jan 29, 2008 | 01:56 PM
Nismo G's Avatar
From the '03's I drove (I worked at an Infiniti dealer) I remember if you floored the 03's while in MM when it got to redline it would shift for you if you didn't. In the 04+ if you were in MM and got to redline it wouldn't shift for you, just bang off the limiter until you did decided to upshift (my '04.5 does this). You don't have to let off the gas to shift at all.
You saying that bounces [once?] then goes below 6700 and shifts for you maybe the same thing I'm trying to describe. Even if the '03 does just bounce for a second before it shifts the later year models will let you bounce off the rev limit all day in any gear.
No i don't think this is right. My 03 will continue to bounce off of every gear until you physically shift it. It won't just hold the shifts to redline and then shift for you. Im pretty sure the 03 and 04 transmissions were the same. I know some people had problems with the 03 transmissions and the valve bodies were "screwing up" and would allow you to choose which gear you could launch from. Someone i knew could be at a stand still and shift into 2nd, 3rd, 4th, or 5th gear using the tiptronic and then go from a stand still like that.
-Sean
Old Jan 29, 2008 | 02:31 PM
Jeff92se's Avatar
Red Card Crew
Depends where your TCM is located. Early autos had them inside the cabin. Later models had them inside the tranny. So phyically it should bolt up. Wiring the damn thing might be a problem
Old Jan 30, 2008 | 09:52 AM
Nismo G's Avatar
Thats what i was affraid of...Thanks!
-Sean
