Newly boosted G = fried stock clutch
Well after two weeks with my single turbo kit installed the stock clutch has finally given in. I knew the clutch was going out so it was no big deal. Jeremy at PF told me that it was slipping on the dyno while he was tuning so I knew it was coming. Any way the stock clutch just slips like hell under boost (you know I have been all in boost). As long as I dont lay into the throttle to heavy it is fine so the car is drivable. My new JWT clutch and flywheel should be here Tuesday so down time will be a minimum. Any way newly boosted G = fried stock clutch. It still fun as hell to drive!!
Just to let everyone know the stock clutch has 49K on it and a little over 1.5K boosted.
my stock clutch was also toasted in 2 weeks. The hardest part is the break-in!!!! You know you have so much power under that hood that you can't use for around 400miles
I had a few Subbies messed with me in the freeway and the Break-in period didn't stop me from racing
Originally Posted by HomieG35
I'm sure it will feel better with no slipping, since more power will be making it to the road!
Don't you need a retune for those upper RPMs now?
haha 2 weeks, jeremy told me it wouldnt last long, i went ahead and had a clutch installed while my car was down there so i wouldnt have to do it later...
but 2 weeks? haha i thought you could atleast get a month out of it, but then again...you said you drove it hard alot and it had pretty good amount of miles on it.
turbo g's are siiiick!
I don't know... I destroyed my JWT clutch at 400 rwhp within 2 months. Saddest $600 bucks spent.
Mine stock clutch and JWT flywheel have lasted about 15k hard driven miles. Now the clutch is slipping in the higher gears. It feels like power loss, because the car doesn't have the neck snapping acceleration it had when I first added the SC. I think I'll go with a JWT clutch to match the flywheel. It should be good for my power level.
Originally Posted by RobbieG35
Should be alot better with the new clutch. I have been wanting to see your car in person.
