Leak on the rear Differential advice plz
Old Mar 1, 2008 | 03:24 AM
Halcyon777's Avatar
So.. I ran over a huge rock today and when i got home to check out the guts of the car i noticed this.
This is what it used to look like.
The fluid is on parts of my exhaust piping near the Dif but it doesn't drip to the floor.
My friend doesn't think this was caused by running over the rock that it could have been there from before; however the fluid seems fresh not like dry or like its been caked on for days.
I'm going to clean it up and see if it happens again after normal driving.
So my questions are how serious is this issue, and what may have caused it?
Old Mar 1, 2008 | 09:38 AM
Bob1's Avatar
Maybe something simple like the plug not tight and you were parked on a hill and some oil dripped out??
Old Mar 1, 2008 | 09:47 AM
Halcyon777's Avatar
In the garage overnight no drippage, but if something cracked or sprayed at once that would explain the fluid on the exhaust pipes.
I did notice a faint burning smell sitting at lights today, starting to think i cracked a seal.
Old Mar 1, 2008 | 11:06 AM
Bob1's Avatar
Only thing you can do is hike it up or get someone with a lift and take a look see. Cracked seal sounds logical.
Old Mar 1, 2008 | 12:10 PM
SILVERSURFERG35's Avatar
The same thing happened to my boys 05 ! There was some problem they were having with them leaking ! He got it fixed under warranty .
Old Mar 1, 2008 | 04:58 PM
GR8TG35's Avatar
From the pics, the spot where it seems to be coming from is pretty high up on the pumpkin.
Did you do a rear gear oil change lately? It seems like its overflowing rather than leaking......Is it possible its leaking out of the fill opening?
Old Mar 3, 2008 | 09:08 PM
chain492's Avatar
do you even know if the rock even hit that part of the car? it could've been there before.
Old Mar 4, 2008 | 12:57 AM
The diff add plug is on the right side of the rear diff !
Old Apr 4, 2008 | 06:58 PM
EvolutionGSR's Avatar
Any updates on this? I have this too....and I have no Idea when it happend to me. Doesn't seem to be leaking anymore, but I do have the crusty lines and it is on my exhaust too.
Old Apr 4, 2008 | 07:25 PM
Does anyone know what that circled part is...and if that is connected somehow to the differential? From his pictures and what I've seen on my car...it looks as if the fluid is coming from right behind there.
Old Apr 5, 2008 | 07:05 AM
elrooko's Avatar
I think that is part of the VDC - it uses that to control the YAW of the car.
Old Apr 5, 2008 | 07:28 AM
Hmmmm sooooo does that mean it is connected to the differential?
Old Apr 9, 2008 | 10:28 PM
marksport's Avatar
On the diff cover, there is a stud that bolts to the crossmember as circled in red. At the top of the diff cover, there is a vent. Could be possible that some of the diff oil came out the vent and down the cover.
Old Apr 9, 2008 | 10:51 PM
Nismo G's Avatar
That part that you have circled is the park leaking. It is a differential mount. You can order solid ones if you want, but you will notice a lot more vibration. I had mine bust not to long ago and i still haven't fixed it. Really doesn't hurt anything. It is just a liquid filled differential mount.
-Sean
Old Apr 11, 2008 | 12:13 PM
Thanks for the info. I don't even know when mine busted. I was under there doing something to my exhaust when I noticed it.
Maybe its time for me to get one of those finned ones and a new LSD =).
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
nascarbuff17
Jul 16, 2015 10:23 AM
