5 different valve bodies?
Old Mar 12, 2008 | 03:09 AM
TURBOTOM's Avatar
a.k.a kleicoupe
I was told the same thing. There is a different vb for every year.
Old Mar 12, 2008 | 03:26 AM
istan's Avatar
Are you having a VB Swap or Upgrade done?
If it's the upgrade, they'll just be reworking your stock VB, which I believe takes a little time.
Old Mar 12, 2008 | 03:59 AM
istan's Avatar
I'm not exactly sure what to tell you. Just get a hold of them. Sorry homie. It sucks to have a crapped out tranny though. Candian has had issues with his tranny and it's f'in annoying.
GL
Old Mar 12, 2008 | 11:58 AM
rookie's Avatar
There are different VBs depending on the year of the car. Recently troubleshooting an 03, finall saw the TCM as well as some relay I've never seen in the passenger side kick panel.
So you got a VB mod from them a while back and it hasn't been running right. You than got a new transmission? Where's the VB that came with the new transmission?
Old Mar 12, 2008 | 12:05 PM
Jeff92se's Avatar
Red Card Crew
If you put a new tranny in, they might not be able to determine which vb you need by your vin. They would have to get the tranny p/n or s/n and research it. But I don't see why they couldn't have modded the VB that came with the new tranny. I assume the new tranny functioned fine before they messed with it?
Rookie. Yes, the early Gs came with a tranny that has the TCM outside the tranny. Right below the engine ecu.
Old Mar 12, 2008 | 12:42 PM
istan's Avatar
They stuck a BRAND NEW tranny in with a VB upgrade and it's been sht since??
Old Mar 12, 2008 | 12:43 PM
rookie's Avatar
That's what it sounds like, they should ideally have modified the new vb in the new trans and put that in there. Only SGP can say if that happened or not.
