rear differential
Old Apr 1, 2008 | 06:53 PM
1ceman's Avatar
rear differential
where is the rear differential on the g35c located?.. and does nebody have a pic because i want to change my differential fluid but i can't find where it's located.
Old Apr 1, 2008 | 07:02 PM
Glex25's Avatar
Administrator
Here is a picture
https://g35driver.com/forums/media-share-g35-coupe-v35/210405-glex-s-new-wheels-rear-differential.html
Old Apr 1, 2008 | 07:05 PM
scarface_613's Avatar
i know that this might not help you out...but are you sure you will know how to change your fluids...every rear wheel drive car is going to have the REAR differential in the BACK....lol just look under the car....
Dont take this the wrong way im not trying to crack on you or put you down, im just saying that maybe you should let someone else change your fluid out...
Old Apr 1, 2008 | 07:46 PM
partyman66's Avatar
It's in the front of the car right in front of the engine.
Old Apr 1, 2008 | 07:47 PM
OCG35's Avatar
plus it's easy to drain, but not as easy to fill...
Old Apr 1, 2008 | 07:56 PM
Glex25's Avatar
Administrator
You drain the fluid through the lower bolt on the differential.
You fill it up through the side bolt of the differential.
You will need a pump to get the fluids into the hole.
The differential takes about 2ltr of fluids or until it starts dripping out.
To loosen the bolt you will need Allen Keys.
Old Apr 1, 2008 | 08:11 PM
not sure of what kind of fluid you will need but im sure someone here could tell you or point you in the right direction
Old Apr 4, 2008 | 02:56 PM
ttrank's Avatar
Grocery getter
I use Redline 75W90. ~1.5qts.
Last time I changed mine I did it off the car when I did my 3.3 swap with the nismo cover.
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
