Thinking of doing drain and fill on my transmission
Old Oct 7, 2008 | 08:33 PM
  #31
marty315's Avatar
Originally Posted by MikeGrote
where is this "filler pipe cover" you are talking about?
I'd like to know this as well. Also, is there a DIY pictorial or video on this? I need to check to see if bythabay has a video on this??
Old Oct 7, 2008 | 09:08 PM
  #32
MikeGrote's Avatar
im pretty sure i found it. its right in the middle right next to the firewall. there is a 10mm bolt that needs to come off to access the trans dipstick and filler tube, someone correct me if im wrong
Old Oct 7, 2008 | 09:09 PM
  #33
marty315's Avatar
Got pics?
Old Oct 7, 2008 | 09:36 PM
  #34
MikeGrote's Avatar
ill check to see if i have any. but all you ahve to do is pop the hood, stand on the pass side and look in the center, a few inches in front of the firewall. should be a cap with a 10mm bolt holding it down and it should say caution on it
Old Oct 7, 2008 | 09:39 PM
  #35
MikeGrote's Avatar
should be just under where i put that red circle, behind the engine there
Old Oct 7, 2008 | 09:42 PM
  #36
marty315's Avatar
Is that where you would pour the new fluid/refill it? See, this is why we need a DIY video.
Old Oct 7, 2008 | 10:18 PM
  #37
MikeGrote's Avatar
im 98% sure thats where you pour it back in. if it makes you feel better, call the dealer and ask. but there is a drain plug to drain and then check/fill behind the engine
Old Oct 7, 2008 | 11:18 PM
  #38
crashnburn's Avatar
just get a tranny cooler and a flush every 30 and u will be good... also that bg magic clean works wonders... saved my accord v6 tranny
Old Oct 10, 2008 | 02:48 PM
  #39
MikeGrote's Avatar
did the drain and fill and drove it so it went through the gears, checked it right after i got back so it was hot. it appears to be overfilled now. i put in just as much as drained out. anyone else have this happen
Old Oct 10, 2008 | 04:37 PM
  #40
joedaddy1's Avatar
you, i could NEVER get a clear reading from that dipstick.
I measured how much came out and it's always 4.4 quarts..
i think others say 3.5qt.. maybe mine was "overfilled" from the factory?
Old Oct 10, 2008 | 06:15 PM
  #41
MikeGrote's Avatar
i got 3.25 out and put the same in, but the dipstick says im way over full
Old Oct 10, 2008 | 06:20 PM
  #42
Jeff92se's Avatar
Red Card Crew
Let it cool overnight and check when cold. Hot level is higher then cold level. Or does the stick have hot/cold levels? I don't know as mine doesn't have a stick!
Old Oct 10, 2008 | 06:35 PM
  #43
MikeGrote's Avatar
it says hot right on it
Old Oct 10, 2008 | 06:37 PM
  #44
MikeGrote's Avatar
im going to redo the process on the 12th so ill just leave it till then. ill just add a quart less when i do the drain and fill the second time
Old Oct 12, 2008 | 04:15 PM
  #45
MikeGrote's Avatar
ok, i think im just really dumb here. ive always checked trans fluid with the engine hot and idling in park. for some reason i was checking it hot with the engine off.
we are supposed to check it with the engine idling in park and hot correct?
