Transmission Removal Question
Old Dec 6, 2008 | 04:00 PM
bflemi3's Avatar
When removing the transmission for clutch/flywheel replacement the service manual does not say that you need to drain tranny fluid before disconnecting drive shaft. My question is...do you need to drain tranny fluid when removing the tranny?
thanks
Old Dec 8, 2008 | 02:06 AM
birdlives's Avatar
no you dont HAVE to. just when your removing the transmission dont tilt it back otherwise you will be spilling oil out of the output shaft.
Old Dec 8, 2008 | 08:24 AM
bflemi3's Avatar
thats what i suspected...thanks bird.
Old Dec 8, 2008 | 08:52 AM
GreenGoblin's Avatar
The goblin resurrection
I made a mess when I did mine
Old Dec 8, 2008 | 10:04 AM
Hi-TechG35's Avatar
The transmission fluid is contained so like Birdlives said don't tilt the transmission.
TL2G35x
Aug 12, 2015 10:30 AM
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
newg37
Jul 26, 2015 09:32 AM
