Not good! need experts advice plz
Old Dec 6, 2008 | 07:58 PM
g35coupe253z's Avatar
i own a 06 g35 coupe and its a automatic, while driving today i was using the manual mode and while driving at 40mph when i shifted to the manual mode, I accidently shift it in reverse its only been done once ever...im really worry about my car right now. Have anyone ever came across this issue? should i be concern about my transmission as much as i should be right now? thanks in advance.
Old Dec 7, 2008 | 12:00 PM
Q45tech's Avatar
Why you purchase a 7 year 100k extended warranty from Nissan to add 30k of protection. AND pay to change the total ATF during warranty to put off spending the $5,000 as long as possible.
Or trade vehicle prior to 70k.
Old Dec 7, 2008 | 04:46 PM
biggz786786's Avatar
u can only put it to neutral while driving, you cant put it in reverse without pressing the brake
Old Dec 7, 2008 | 07:33 PM
^ hey hey hey, lets not get testy
i have a 5AT too, so i can relate, my answer is relative to the question
in other words im saying that it shouldn't go into reverse while driving, its a safety thing, im not bashing on him, am i?
Old Dec 7, 2008 | 08:45 PM
^oh lol
sorry my mistake
Old Dec 8, 2008 | 11:51 AM
yea i accidently press the button but after i see rev i switch back real fast
Old Dec 8, 2008 | 12:40 PM
05DGx's Avatar
Automatic transmissions react differently in different cars, so take what I'm saying with a grain of salt. Its not an excuse to throw your car in reverse to try it out.
Anyways...
Some transmissions have valve bodies that are programed not to allow the car to switch into a reverse gear while you're in motion. So depending on the car (and I am not sure about the G), the car will either not let the transmission engage in the opposite direction, or it will try to engage reverse and slow down the car.
You said that you accidentally moved the shift lever and saw the car rev? Are you sure you didnt just knock it in neutral?
In all likelihood, your transmission will prob be fine. If you have any issues, just take it to the dealer/trusted mechanic, and ask them to have a look.
Old Dec 10, 2008 | 11:54 AM
sliderg35's Avatar
+1 Yeah - did the car actually go into reverse? I doubt it - I did that once (I don't remember the circumstances) but even though the indicator went to "R", the transmission knew that would be a bad idea and it did not react. I just put the shifter back into "D" and everything was fine. Just make sure you don't slow down while it is still in "R". Once you get slow enough, it will do it - but that would be down around 5 kph.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
miata007
Aug 17, 2015 04:36 PM
ghost_g35
Aug 7, 2015 10:31 AM
