Shifter problem or transmission?
Old Dec 15, 2008 | 11:05 AM
JD_AND_DA_G_RIDE's Avatar
Guys anyone that can provide some feedback would be much appreciated. Although I will be going to the stealership (trying to avoid them) to find out what's wrong I don't want to get had and the white glove from them
Problem: Past week or two the shifter itself started to feel looser than normal. Now 3 days ago all of a sudden I can't "reach" 5th gear; I had to really throw it hard all the way to 6th; once I'm on sixth, if I can keep the shifter aligned then I don't have a problem getting it into 5th.
I've found limited threads about a bolt coming loose and/or bushings wearing out and having the same problem (but there's no follow up).
I can't say that I'm a mechanic and know all there is too know but if it was the synchros or the actually tranny wouldn't have I been having issues shifting, grinding, etc?
Thanks,
JD
Old Dec 15, 2008 | 11:16 AM
canucklehead's Avatar
...sounds like an issue for the dealer to assess. the symptoms don't sound good. you are still under your powertrain warranty aren't you?
Old Dec 15, 2008 | 11:46 AM
Nope, and it's my daily driver so that's why I'm crapping bricks I guess with all the issues the 03 6MT's had I should feel lucky it took this long?? I'm already at 128K miles.
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
saskicker32
Aug 11, 2015 02:12 PM
