Cheapest to replace clutch?
Punchline: what's the cheapest way to replace my clutch? Dealer quoted me $2500, which i cannot afford right now.
Not looking for a performance upgrade, just want to replace the damn thing for as little as possible. How much would I be looking at for a basic OEM-like aftermarket set-up, for parts and labor?
Thanks!
(If you're wondering: my car has 82k miles on it, clutch was replaced at 45k under warranty. clutch is working fine insofar as it doesn't slip or anything, but it makes a horrible grinding noise when i put in the clutch when the car is cold. it's bizarre, and service advisor says it just needs to be replaced)
Thanks!
mine does the same thing only when its cold and i first turn it on. but its more liek and errrrrr sound. my clutch has less than 25k on it and it is fine. tell them to blow it out there a$$
Originally Posted by snakes1021
mine does the same thing only when its cold and i first turn it on. but its more liek and errrrrr sound. my clutch has less than 25k on it and it is fine. tell them to blow it out there a$$any opinions on my question?
t/o bearing and pilot bushing
where are you located i do it much cheaper. Exedy factory replacement clutch and keep your flywheel, probably will have a bit of chatter with it as the flywheels should be replaced but you might be ok, can't garuntee you that but it will still work correctly but might make some noise on engagement.
i got jwt clutch flywheel, ss clutchline, TOB/pilot and everything you need from one of the vendors for 775 and it cost me 400 for the install. cant cut the OEM flywheel and the lightweight one with JWT clutch isnt as noisy as every says.
Daniel k.
Nov 3, 2015 09:52 AM
