Stupid question - flywheel/clutch combo
Old Jan 11, 2009 | 12:43 PM
lekker_droom's Avatar
If I was to put it a Carbonetics twin disc clutch along with the lightened flywheel, would these show up at all on a dyno?
I think obviously not but still curious. These mods would show up on a time trial for sure but seriously would there be any gain on a dyno from them?
Old Jan 11, 2009 | 01:31 PM
mIKE's Avatar
Theoretically, yes. Realistically, no.
Old Jan 11, 2009 | 01:36 PM
dofu's Avatar
20 Year Member
Think of it like a 4.08 final drive... technically, you aren't making more power, you're just getting up the revs faster
Old Jan 11, 2009 | 01:41 PM
Kinda of what i was thinking too. It'll get you there faster but your technically, as far as i know, not making more power, just getting there faster.
Old Jan 11, 2009 | 01:49 PM
mIKE's Avatar
Technically, a lightweight flywheel will give you more power at the wheels.
Wheels/tires are a rotating mass that robs power, right? Flywheel is the same concept, just on a much smaller scale.
Realisticaly speaking, the gain from a flywheel is so small that it falls well within the margin of error on a dyno.
This is also why dynapacks read higher than dynojet/dyno dynamics/mustang; they connect to the hubs, which eliminates the wheels/tires variable.
Old Jan 11, 2009 | 02:46 PM
dofu's Avatar
20 Year Member
I can't argue about the flywheels, but as for this - technically, dynos need to be "tuned" too...
The Dynapack at Blacktrax has been correctly calibrated, and it reads about the same as the Dynojet at DynoSpot, which really isn't that much higher than my friend's notoriously low reading Mustang. My car makes about 20 more horses on the Dynapack and Dynojet than the Mustang... I can get those same numbers on other Mustangs in the area...
Old Jan 11, 2009 | 02:58 PM
mIKE's Avatar
IMO, any dyno that can "read what other dynos read" is suspicious...
Lightweight wheels and tires will register as additional power on a dynojet (compared to heavy wheels and tires); it will have absolutely no impact on a dynapack.
Old Jan 11, 2009 | 03:04 PM
dofu's Avatar
20 Year Member
It's all on how you set up your dyno. Correctly set up, it should compensate for more than you are thinking it does. I think the only variable dynos can't compensate for is air density.
And IMO, up to about 10hp difference between different dynos would be pretty similar, depending on weather.
Eomfd
Aug 29, 2015 12:42 AM
Blakearold
Aug 27, 2015 12:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
