are gear oils all the same?
Old May 31, 2009 | 10:43 AM
Swivel's Avatar
Moderator
Originally Posted by MarkG
I don't know much about ATF other than put it in the power steering, but X2 on the Amsoil Severe Gear.
x3, that's what I run.
Old Sep 10, 2009 | 12:30 PM
PAIXAO's Avatar
Originally Posted by Billabongi
Is there any issue with using GL-5 80w-140 I mean I know its not ideal but is it going to damage anything?
I've heard you may lose a bit of hp but ive also heard it lubricates the gears much better and handles heat better. Is this true or all rubbish?
BUMP for an answer to this question...
Old Sep 10, 2009 | 12:39 PM
vincentl's Avatar
Well, a thinker fluid would make something else work harder. I would ALWAYS use what is reccomended because it's probably the best choice. "Protecting" the gears is kind of strange because...well that don't really go bad under normal use. Syncros go bad.
Old Sep 10, 2009 | 12:41 PM
bythabay's Avatar
The viscosity is too high at operating temp;why would you want to put that in?
Old Sep 10, 2009 | 12:45 PM
PAIXAO's Avatar
An Infiniti Master Tech recommended it to me this morning. Says he puts it into a lot of G35's and 350z's. He's been working on Nissans/Infinitis for over 20 years so I tend to listen when he recommends something. BG Ultraguard 75w140 synthetic is what he recommends.
Old May 18, 2010 | 06:13 PM
WhosRich's Avatar
Bump it up. What are you guys running in your differentials? Any pro's or con's to the fluid you chose?
Old May 18, 2010 | 10:27 PM
G35fromTO's Avatar
I put Castrol Hypoy C Gear Oil (http://www.castrol.com/castrol/secti...tentId=7036192) into mine just recently. Honestly, don't really know any pros or cons. Castrol should be good and I wanted conventional oil.
For transmission I used Nissan MTF.
Old May 18, 2010 | 10:38 PM
abcdo4dkIdjkm's Avatar
Im running the mobil 1 synthetic gear oil 75w90. Haven't had any issues.
In the gearbox, OEM Nissan gear oil
Old May 18, 2010 | 10:45 PM
jonnylaw's Avatar
I run Silkolene for my Quaife ATB, nissan for the m/t fluid
Old May 21, 2010 | 06:52 PM
importroller's Avatar
Im about to do my rear diff in my 04 5AT sport package (came with 18s). I gotta stop and pick up the fluid tonight. I do not believe that it has LSD, but is there a way to tell without getting the rear end up off the ground and spinning the wheels?
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
9tray turbo
Sep 29, 2015 10:22 PM
wow600rr
Sep 28, 2015 11:50 AM
