Transmission Spacers from GTM
Old Jul 27, 2009 | 05:42 PM
Nickk6's Avatar
Anyone know about these? I got transmission spacers from GTM. They are used with the engine spacers! Now that I am installing the motor I see I have 2 bolts per side on the transmission brace. I talked to Sam over at GTM and he told me there was only one bolt per side (I only have 2 spacers). Am I confused or what? Here is a picture of the underside of my car. I don't see how there could only be one spacer per side unless something is suppose to be bolted down uneven. I am really suprised Sam couldn't help me when they build tons of these boosted cars. Anyone else with knowledge know what I am doing wrong?
Brace attaches at both sides of frame
Closeup of drivers side of brace
Old Jul 27, 2009 | 06:52 PM
JSpec350GT's Avatar
Transmission spacer? What does it exactly do???
Old Jul 27, 2009 | 08:44 PM
Nickk6's Avatar
It adds space between the car and the transmission I think. I installed engine mount spacers as well...so I assume they work together to give more space in the engine bay to fit all the goodies that go in there.
Old Jul 27, 2009 | 11:02 PM
Nickk6's Avatar
Has anyone even heard of engine spacers? I hope I am not a guinea pig of this setup.
Old Jul 28, 2009 | 01:52 PM
Tollboothwilley's Avatar
Never heard of them. They are supposed to space the transmission from the frame of the car? Hrmm...
How big are the spacers...are they like over-sized washers??
Old Jul 28, 2009 | 07:49 PM
OCG35's Avatar
what exactly are you trying to accomplish?
Old Jul 29, 2009 | 02:10 AM
Nickk6's Avatar
Not sure.
They look like washers, about 1/4 thick steel, 1" in diameter.
I used engine spacers mounting my engine to the subframe. Now I am ready to install the engine and I don't see where the transmission spacers go.
This is a before shot when my transmission wasn't attached so you can see what I am doing.
Old Jul 30, 2009 | 06:29 PM
GTM's Avatar
GTM
The spacers go between the transmission and the bracket, there are 2 bolts. The 4 bolts go to the frame.
Hope this resolves your problem, let me know if you need anything - it seems there was some miscommunication.
-George
Old Jul 31, 2009 | 02:51 AM
Nickk6's Avatar
Hey George.... I believe you guys moved? I understand Sam was busy, no one answered the phone all week and he said the internet was down. Do you possibly have a picture? I'm a newb and don't apparently know what the transmission or the bracket is.... Thanks.
On the internet I found a picture of what looks like the transmission with the transmission bracket attached to it? I see that single bolt that is holding the bracket to the transmission mount (rubber piece)? Do spacers go above the rubber piece?
Old Jul 31, 2009 | 04:15 PM
Nickk6's Avatar
Edit* I got it, just needed some muscle.
g.spot
May 9, 2016 10:54 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
