increasing the stall RPM on 5AT
Old Aug 31, 2009 | 10:34 AM
Gian124's Avatar
How much can you increase the stall RPM on a 2003 5AT without throwing codes and running into ABS problems?
Thank you in advance for input!!
Old Aug 31, 2009 | 11:01 AM
Canadian's Avatar
Canada, eh?
You should be able to increase it as high as you want. You will need a new torque converter, its not as simple as just changing a setting. My stall is set at around 3100 with my torque converter.
Old Aug 31, 2009 | 09:08 PM
Gian124's Avatar
I know upstairs (in Canada... above us) you guys need not worry about emission codes. Curious if any codes are thrown when increasing the stall (and yes, doing a TC upgrade right now).
Also, did you have to change anything else to compensate for the stall rpm increase in order to get the traction control & ABS to cooperate?
Old Aug 31, 2009 | 11:12 PM
GT-ER's Avatar
It shouldn't affect anything other than your stall.
Old Sep 1, 2009 | 12:42 PM
Tollboothwilley's Avatar
It won't change anything. Most people have the stall set around 3200 with the 5AT for optimal performance.
Old Sep 2, 2009 | 04:00 PM
Canadian's Avatar
Canada, eh?
No codes, nothing else was affected. Well, now I can spin the tires from a standstill. But I don't..tires are too expensive.
Old Sep 6, 2009 | 05:05 AM
JUM3's Avatar
noob questoion: how would you go about changing it and why?
Freeman186
Sep 6, 2023 10:07 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
Jnm07
Sep 5, 2015 01:16 AM
