stricky suggestions for drivetrain section
Old Sep 30, 2009 | 07:55 AM
idrive_MD's Avatar
So this is one of the few sub forums that doesnt really have any stickies supporting it and it seems like a lot of the same questions pop up.
"What trans fluid should use?"
"What diff fluid will work?"
"Any suggestions on which rear end I should go to?"
"Do I have the upgraded trans?"
etc etc
So maybe someone can put together a sticky pertaining to these three areas at least. I suggest something that details the transmission in terms of fluids, differences in the model years and possibly clutches/flywheels. Pretty much the same thing for the rear pumpkins, cover fluids, LSD options, rear end swaps, what OEM FD's were available etc.
I unfortunately don't know most of these so not even I can put this together.
Someone want to take the lead on this?
Old Oct 2, 2009 | 10:04 AM
idrive_MD's Avatar
i guess there's no love for this idea from any of the admins or some uber member who might know the information that we're all seeking?
Old Oct 6, 2009 | 11:46 AM
davesxx01's Avatar
Sounds like a great idea, first place I try to look at before posting my own questions!
Likely going to replace my clutch setup soon and have been researching flywheels.
I'll post what I found next post.
Mods; If you do make a stickie out of this info that would be great!
If anybody else has info on clutches please post up!
Im guessing mods can cut and paste info into a stickie?
Old Oct 6, 2009 | 11:58 AM
davesxx01's Avatar
Flywheel weights:
Stock......27.6 lb
SPEC (ST)28.0 lb Steel
Nismo......21.6 lb
Exedy......19.6 lb
RPS.........18.0 lb
ACT S/L...16.9 lb
Stillen......14.25 lb
JWT........14.0 lb
Z1..........13.75 lb
SPEC........13.0 lb Aluminum
Old Oct 6, 2009 | 03:28 PM
idrive_MD's Avatar
thats a start I suppose.
Old Jan 26, 2010 | 11:16 AM
davesxx01's Avatar
Anybody else have more info to share??
KruZZe
Feb 27, 2023 05:04 PM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
