RPM's at 80 MPH
Old Jan 11, 2010 | 11:18 AM
  #331
Tollboothwilley's Avatar
Originally Posted by alfhasg35
2005 6MT Coupe with new motor under 200miles..
3100rpm at 80mph in 6th gear...
Originally Posted by speeddream
I remembered to look at my rpm's finally. So last night i noticed that at 81 mph i was at 2900 rpm's. 03 6mt sedan
Look at the diff. Both 6MT with the same FD but off by 200 rpms. 200 rpms is typically the diff between 3.3 and 3.5 FD
Old Jan 11, 2010 | 03:27 PM
  #332
alfhasg35's Avatar
where do you look..? and how...?
my car is bone stock as far as the FD .... so..?
Old Jan 11, 2010 | 04:21 PM
  #333
OCG35's Avatar
its not uncommon for the tach to be off by that much though... I dont know about being off to another car - but off from actual rmps (as noted on several dyno pulls)...
Old Jan 11, 2010 | 04:25 PM
  #334
NFSP G35's Avatar
? = 2B || !2B
My tach is off by about 50 RPM if I'm cruising. But if I floor it, the tach does 'lag' behind the real RPM. IDK by how much. I'd have to datalog to see.
Old Jan 11, 2010 | 04:36 PM
  #335
ya, that can happen. Sometimes the tachs are not very accurate. Plus, you have to get the rpm while you are on flat ground.
I'm sure you have the 3.53 Final Drive differential it just shows you how they can be off.
Old Jan 11, 2010 | 05:12 PM
  #336
Jeff92se's Avatar
Red Card Crew
Won't it depend on the tire dia also? Even with the same tire size, the actual dia various amount different makers.
Old Jan 11, 2010 | 05:18 PM
  #337
OCG35's Avatar
^^^ speed yes, rpm no.
Old Jan 11, 2010 | 05:19 PM
  #338
NFSP G35's Avatar
? = 2B || !2B
^That post kinda sounds like you're saying dire diameter would affect your RPM or make your tach read wrong. I know what you mean though. Changing tire diameter would change the ratio between RPM and actual speed. It shouldn't change the ratio on the dash though since the speedo works off the tire RPM (independant of speed/tire size) but if your were compairing RPMs to speed on a GPS then it would.
Old Jan 11, 2010 | 05:25 PM
  #339
tire size will affect the RPM slightly, but should be no more that +/- 50 rpm. Smaller diameter tires will change the true speed of the car - thereby affecting the RPM at that given speed.
^^ same thing you were saying i think haha, repost.
Old Jan 11, 2010 | 05:30 PM
  #340
NFSP G35's Avatar
? = 2B || !2B
^Add to this the fact that you could have a +/- 100 RPM inaccuracy in the tach combined with a +/- 5 MPH inaccuracy in the speedometer... and if they're inaccurate in opposite directions... well, you get the idea.
Really the best way to get an accurate reading is with datalogging software showing your true RPM and a GPS to show your true speed.
Old Jan 12, 2010 | 12:17 AM
  #341
This is why cruise control is disabled with a different FD (it has to do with the TCU)
Old Jan 12, 2010 | 12:48 PM
  #342
DaveB's Avatar
Toll- I'm assuming your CC is still working below 79mph?
Old Jan 12, 2010 | 02:30 PM
  #343
OCG35's Avatar
does yours work Dave?
Old Jan 12, 2010 | 02:58 PM
  #344
DaveB's Avatar
Haven't installed it yet. Might be another week or two.
Old Jan 12, 2010 | 06:49 PM
  #345
Yes, my CC works, and it works all the way up to 86 MPH.
