Do i have a VLSD?
Old Oct 30, 2009 | 12:51 AM
keff108's Avatar
Do i have a VLSD?
A little confused here. Took my car to my buddy's shop last night to get inspection and emissions done. So we put my car up on one of the lifts and noticed that it appeared I had a limited slip. Both rear wheels spun in the same direction in neutral when spun by hand. Didn't seem right tho because I have a 2004 G35 Coupe 5at. I honestly thought that only the 6mt's came with the VLSD.
So I am really confused as to if i have it or not. I tried the "burnout" test and it appeared i do have a VLSD. The car left two identical tracks on both sides measuring the exact same distance. Mind you i was careful and did this in my driveway away from traffic.
My car came loaded from the factory with every option except Navigation. i have the 18" wheels. And Aero package. Don't know if any of this helps I would just like to know if I have one or not. Thanks.
Old Oct 30, 2009 | 02:25 AM
ntrinsik's Avatar
As far as I know.. '03-'04 with the 18" wheels came with VLSD.
'05s didn't.. but I just got the 3.5+VLSD pumpkin swapped this past weekend.. Loving it!
Old Oct 30, 2009 | 04:16 PM
Tollboothwilley's Avatar
I think all coupes came with VLSD...
Old Oct 30, 2009 | 04:48 PM
nghiars's Avatar
^^^ All 6mts have the VLSD and some autos came with VLSD, mostly the ones with sprt packages.
Old Oct 30, 2009 | 04:58 PM
Law to the Rence's Avatar
all 6MTs and 5AT coupes with sport package have VLSD, not sure about sedans
Old Oct 30, 2009 | 08:15 PM
mIKE's Avatar
Neither test is indicative of having a VLSD. The only way to tell is to turn VDC off, find an SAFE and open place, and do donuts. If both tires are spinning, then you have a VLSD. If only the inner one is, then you don't (or your VLSD is worn out).
In all reality, all VLSDs are generally open by the time you hit 60k miles due to wear and tear.
Old Oct 31, 2009 | 01:41 AM
If it was an open diff you wouldn't see both wheels spinning the same direction when the trans is in neutral.
Old Oct 31, 2009 | 11:20 AM
mIKE's Avatar
Unless you have significantly uneven traction, both tires will spin.
DaveB has proven this multiple times, with videos.
Old Oct 31, 2009 | 11:42 AM
speedracerg35's Avatar
yeah, go do donuts in a parking lot to see if you have vlsd. that's a great idea. as a matter of fact...best idea ever.
MrIP35
Oct 25, 2015 11:13 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Glex25
Archived Sales
Jan 23, 2008 10:06 PM
madchef
Apr 21, 2005 01:29 PM
