Auto Transmission Fluid
Old Aug 25, 2004 | 04:06 PM
G35Performance's Avatar
Hi anyone have any experience with other brand of transmission fluid. I know we shouldnt mess with it, but which ones do you recommend?
2003 G35 Sedan AT
Stillen Intake+Z-tube, True Dual Exhuast
Crawford Plenum V5
Technosquare Ecu
7 wire Grounding Kit
Old Aug 25, 2004 | 06:24 PM
cato's Avatar
SouthernComfort Moderator
Re: Auto Transmission Fluid
Infiniti will void your warranty if you use anything other
than the Jmatic in the G35 automatic transmission.
Beware!
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Aug 25, 2004 | 08:37 PM
Msedanman's Avatar
O.F. Administrator
From what I understand, no other brand will match the uniqueness of Nissan's J-brand fluid. Apparantly nothing else is as good for our trannies.
Couple those 2 things with knowing that every tranny failure is investigated by Nissan techs for tampering, and you can see that it's just not worth changing out the fluid. [img]/w3timages/icons/frown.gif[/img]
I recommend none.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Aug 26, 2004 | 07:43 AM
exagorazo's Avatar
I did a lot of research into this because I considered changing to synthetic fluid.
I talked to transmission experts, including Level 10 in NJ and Mobil's technical support people. Mobil said that Nissan usually doesn't publish specifications for their fluid. As a result, Mobil can't match specs they don't have.
Level 10, a world authority on Nissan transmissions, uses only Nissan fluid.
Using other fluids will void the warranty on the transmission.
Bottom line, use only Nissand fluid per the owners manual.
Old Aug 26, 2004 | 07:57 AM
Q45tech's Avatar
The 5AT has a new design dual lockup clutch and is extremely precise about just the right stick slip characteristics of the ATF. Also it is a full synthetic in the same sense as Mobil 1 ATF is synthetic [no natural base oil].
Toyota and Honda have similar premium ATF just the characteristics are slightly different.
Like any ATF it should be changed every 30,000 miles if you expect to own the car beyond 70,000 miles.
Sure the fluild may function to 100k but what damage is done by the long interval.
Considering the $4500 replacement cost a few hundred every 2 years is very good insurance.
Old Aug 27, 2004 | 04:54 AM
Thx for the infos, the reason i ask is because my car is in the shop due to a little accident and my transmission hose got torn. Guess ill stick with stock ATF.
2003 G35 Sedan AT
Crawford Plenum V5
Technosquare Ecu
Old Aug 27, 2004 | 10:38 AM
exagorazo's Avatar
If you are concerned about your tranny fluid, add an auxilliary transmission oil cooler. For a total investment of about $100, you will have some additional tranny insurance. Reducing oil temperature cannot but help the life of the fluid and the transmission.
<font color=blue>Details of my install to follow.</font color=blue>
<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 08/28/04 11:50 AM.</EM></FONT></P>
Old Aug 27, 2004 | 11:00 PM
augie's Avatar
talking about tranny oil, my local infiniti dealer recommends i dont change it until i hit 60k cause of the special fluid? i want to change it now that i just 30k. what do you guys think? they want to charge $129
Old Aug 28, 2004 | 05:23 AM
eldy's Avatar
You got pics of the Hayden installed? What complications did you run into installing it?
<font color=blue>2004.5 Coupe ^ 5AT ^ DG/W ^ Z Tube</font color=blue>
Old Aug 28, 2004 | 07:29 AM
exagorazo's Avatar
The complications I ran into were that it didn't fit! I just found out yesterday.
I had asked my mechanic for acceptable dimensions and he did his best looking through the grill and from the top. Unfortunately, some unforgiving obstructions, like the cylinder on the passener side on the front side of the radiator, prohibited the use of this size cooler. There are also some potential issues with the bolts that hold the horns on, but I think that the brackets can be gently bent towards the front of the car. Also, keep in mind that this is a sedan.
When I found out, I tried to edit my post to remove the model number, but, alas, the time had elapsed. So forget that model number.
I'm now in the process of getting a smaller size cooler.
<font color=red> Bill, I edited your previous post for you to exclude the hayden p/n, and I noted that your install details would follow.</font color=red>-- Colin
<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 08/28/04 11:57 AM.</EM></FONT></P>
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
vamarris
Sep 26, 2015 12:56 PM
blnewt
Sep 25, 2015 01:48 PM
