Changing ATF fluid
Old Feb 17, 2010 | 12:43 PM
Canadian's Avatar
Canada, eh?
Originally Posted by DaveB
From what I've seen of JATCO 5AT, the filter is technically not serviceable.
I've taken my valve body off my car twice, the filter is not serviceable but it is replaceable. You will have to drop the pan though, it is not a very simple procedure and is probably not necessary.
Old Apr 20, 2010 | 01:07 AM
hilock's Avatar
Here's what I'd recommend assuming you're fluid hasn't been changed ever or hasn't been changed in a long time (40K+ miles).
1) On a COLD* engine, drain the tranny. Measure the amount that came out to the nearest 100ml and replace with the same amount. Use empty oil containers with 100ml graduations to get a drain measurement. *Tranny fluid expands 15% when hot so replacing with cold fluid can skew fluid levels.
2) Drive 100 miles or so and do the same drain/fill procedure.
3) Repeat the drain/fill procedure one more time.
4) Once completed, perform a single drain/fill every 15K miles.
Remember, heat is the leading killer of transmissions and much of the heat can be related to old ATF.
Replace with Nissan S-matic only. J-matic is no longer available. Do not use any other brand. No exceptions and I won't debate this.
Thanks for the great recommendation. After doing some research, what you said makes a lot of sense for cars that have not had regular changes in the past.
I'm a big Amsoil supporter so I'll be putting in Amsoil transmission fluid. You can research on the internet that there are alternative brands that meet the matic J specs
Old May 21, 2010 | 12:23 PM
importroller's Avatar
Looks like this is my task this weekend. should be fun.
Old May 22, 2010 | 02:05 PM
Canadian's Avatar
Canada, eh?
Originally Posted by HomieG35
I never really measure, I just let it sit for 30 min or so and then start to refill with a little less than full and keep checking it. How's the VB working out for you? I don't meet too many other people with the SGP trans... specially now that that went under. Let me know though, I still have contact with Mark if you need any help with it.
The VB is working fine, I only had SGP do the valve body. They didn't go the whole trans. I'm having a problem with 5th gear right now and its at a stop. I'm actually waiting on an answer today.
Old May 24, 2010 | 01:59 PM
when i drained mine, i got a little over 4qts of fluid out of the transmission. I didn't do a full flush
Old Jun 2, 2010 | 04:36 PM
echang0501's Avatar
do you know if its safe if i use some matic j and matic s together???? please help
Old Jun 2, 2010 | 04:47 PM
rcdash's Avatar
Yes, it is safe. I did it and nothing bad happened. 7k miles later, doing another drain and fill with S-matic. 4.5 qts for a drain/fill here. The reason flushes are not recommended after a long service interval is that you can actually block off fluid channels with debris during a flush procedure due to the amount of solid material that can be picked up into the fluid. A drain minimizes transmission of debris accumulated in the pan from being swept through the transmission.
Old Jun 2, 2010 | 04:50 PM
echang0501's Avatar
thanks mang.
Old Jun 2, 2010 | 05:08 PM
thescreensavers's Avatar
Mr.202?
I had my tranny completely flushed at 39k. And no you cannot block off fluid channels with debris during a flush.
All they do during a flush is pour the fluid in at the same time the tranny pump is pumping the old fluid out until the fluid coming out is the same color as its going in.
I am going to do it again at 70k
Old Jun 3, 2010 | 04:31 PM
I'll be doing another drain and refill in about 15K miles. it was extremely easy to do
Old Jun 9, 2010 | 11:00 AM
Tollboothwilley's Avatar
When you do a drain/fill make sure to disconnect the lines going into the stock(or aftermarket) cooler which are going into the radiator(stock). Letting these fully drain will get out another 1.5-2 quarts of fluid.
Old Jun 15, 2010 | 12:10 PM
rcdash's Avatar
Ok, whatever you say. That is the stated reason that flushes are not recommended. Whether you choose to believe it is up to you.
Old Jun 17, 2010 | 12:17 PM
^ what you are referring to is different than what he's talking about.
He is talking about a full fluid exchange where the pump is doing the work. You are talking about having them PUMP fluid in and having an external pump doing the work.
Both of you are correct.
Old Jun 18, 2010 | 05:09 PM
  #30
Maciuniu's Avatar
Just a reminder to EVERYONE... NISSAN CAME OUT WITH J-MATIC AGAIN... all tech's were told that if J-MATIC IS CALLED OUT, USE J-MATIC. IF S-MATIC IS CALLED OUT, USE S-MATIC.....GGGGGGGGGGGGGEEEEEEEEEEEEEE... i wonder why..??????.So from now on you can still buy J-Matic if you want. Why is that, i guess nissan of US should know
Eomfd
Aug 29, 2015 12:42 AM
All G'd Up
Aug 29, 2015 12:40 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
NemesisGee
Aug 11, 2015 07:10 PM
newg37
Jul 26, 2015 09:32 AM
